jdkrueger Posted April 16, 2014 Share Posted April 16, 2014 I've saved recordings to the SD card and transferred them onto my desktop. However I cannot figure out how to play them on my computer to play in iTunes or load them on to youtube. I want to be able to play them other than on my amp. I read the spider jam advanced guide and I didn't see anything that would help. Please advise. Quote Link to comment Share on other sites More sharing options...
gary9605 Posted April 17, 2014 Share Posted April 17, 2014 These should be WAV file format. What you need is a utility that converts WAV into MP3. Do a google search for WAV to MP3 or whatever you need. Quote Link to comment Share on other sites More sharing options...
jdkrueger Posted April 17, 2014 Author Share Posted April 17, 2014 They are not in WAV format. Is there a way to have them save as WAV? They are always .JAM files and do not play on the computer. Why are they JAM files? The above does not help. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted April 17, 2014 Share Posted April 17, 2014 You shouldn't need a converter. I'm pretty sure you can save your recording as a WAV file while the card is in the Spider Jam then you can import it into your DAW. After you record something or load a recording currently on the SD Card press the save button and then scroll down to look at your options, you should see something that says "Save recording as a wav file". 1 Quote Link to comment Share on other sites More sharing options...
jdkrueger Posted April 20, 2014 Author Share Posted April 20, 2014 OK i saw how to save it as a WAV file... however I get "Error writing to card"... meanwhile there is no issue saving it as a JAM file. There is plenty of space on the card. Still can't solve the issue Quote Link to comment Share on other sites More sharing options...
Dedoxinator Posted January 29, 2015 Share Posted January 29, 2015 Format your SD card in the Spider Jam first. Then do as Brazzy said. It will work fine. 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 29, 2015 Share Posted January 29, 2015 Another thing I've learned is that after I make a recording and save the wav file to the card I can just take the card out without powering the amp off. As long as I don't power off, the recording will remain in memory even if I reinstall the card back into the Spider Jam. This is nice. Example, I make a few riffs I think might be good to use. Each time I make a riff and save it to the card I have to give it a new name by using the selector wheel. This can be a drag, lol. So I make a few riffs name them accordingly starting with "0EW_RECO", "1EC_RECO", etc. I only change the first character 'cause it's quicker for me. When doing this I found out by mistake to not use characters like ": ; . ,", I forget which ones I used but when I went to read the card with my computer the file was corrupt, so I just stick to numbers or letters. Hope this helps a little. 1 Quote Link to comment Share on other sites More sharing options...
Dedoxinator Posted January 29, 2015 Share Posted January 29, 2015 Good tip Brazzy. I have alays turned the amp off 'just in case', but will certainly use your method from now on. 1 Quote Link to comment Share on other sites More sharing options...
a1terrier Posted February 18, 2015 Share Posted February 18, 2015 just in case you need a converter, I used to use Koyote. It was good and free. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted February 18, 2015 Share Posted February 18, 2015 just in case you need a converter, I used to use Koyote. It was good and free. Do you have the correct EXE file to share or the link to the correct program. That would be cool if it works. I gave up on that long ago. Quote Link to comment Share on other sites More sharing options...
a1terrier Posted February 18, 2015 Share Posted February 18, 2015 Hi Just googled Koyote and it took me to cnet download site. Works ok, don't think it does Jam files tho Quote Link to comment Share on other sites More sharing options...
Brazzy Posted February 18, 2015 Share Posted February 18, 2015 Hi Just googled Koyote and it took me to cnet download site. Works ok, don't think it does Jam files tho I understand, which is why I asked before I just go and install more programs. I've got to the point where I need to know as much as I can about a program before I just trust it. Thanks! Quote Link to comment Share on other sites More sharing options...
a1terrier Posted February 18, 2015 Share Posted February 18, 2015 No probs Brazzy. Think cnet is pretty safe. Koyote also good for converting backing tracks from Free guitar backing tracks to play on SJam 1 Quote Link to comment Share on other sites More sharing options...
richard0250 Posted April 4, 2015 Share Posted April 4, 2015 To All the members on this forum about converting the MP3 to WAV files, i have been pulling out what hair I have left over converting lesson files in to WAV files. I have tried to many converters to say, all fail. Today i found the best and easy free online converter that works very well, :) :) :) :) the LINK http://audio.online-convert.com/convert-to-wav i hope this will help all, i think the amp is very good, just don't understand why they would create it this way when MP3 is best Quote Link to comment Share on other sites More sharing options...
wilhow Posted May 1, 2015 Share Posted May 1, 2015 Half way down the page is a j2wsetup,exe for JAM to WAV or visa versa. http://www.hispasoni.../361562/pagina2 Quote Link to comment Share on other sites More sharing options...
Blubarb Posted May 8, 2015 Share Posted May 8, 2015 G'day Brazzy et al. Not sure but I wonder if Audacity will do the trick. Brilliant for MP3 to .wav. 1 Quote Link to comment Share on other sites More sharing options...
Ace_Handler Posted October 14, 2016 Share Posted October 14, 2016 I've been using foobar2000 for years for all my audio conversions. Using it right now to play .flac files via bluetooth to my 2.1 soundbar :-) It too is free. Will convert most everything on the planet. Quote Link to comment Share on other sites More sharing options...
Ace_Handler Posted October 15, 2016 Share Posted October 15, 2016 Just finished converting the Lawrence Fritt collection of blues backing tracks from 192kbps .mps to .wav mono with foobar2000 (total about 1.45 GB at nearly 5 hours playing time!). I've uploaded a screenshot of the settings screen. Just import the files into the foobar (drag & drop works fine) and right-click (after selecting all) and choose 'convert'. The ...... at the bottom brings up the conversion options screen, choose your options. I chose .wav; convert to source folder (I'll move them after); and in Processing, Downmix channels to mono. Worked like a charm :-) Quote Link to comment Share on other sites More sharing options...
lovemyspider23 Posted October 21, 2016 Share Posted October 21, 2016 Nothing on this page works please help jam to anything that will play my tracks from amp to anything else.... Quote Link to comment Share on other sites More sharing options...
chrisgrav Posted January 25, 2018 Share Posted January 25, 2018 Audacity can play the jam file and convert it to MP3. And it's free. Quote Link to comment Share on other sites More sharing options...
ronsmith12 Posted December 7, 2020 Share Posted December 7, 2020 This is very useful content i have used this Mp3 converter Quote Link to comment Share on other sites More sharing options...
