kebon29 Posted February 12, 2025 Share Posted February 12, 2025 I thought there was a way to change the location of the Bank switches. Am I wrong? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 12, 2025 Share Posted February 12, 2025 You can’t change the location. You can change the behaviour, like make them additional Stomp switches, or make them Preset/Snasphot up/down switches, rather than Bank switches. Quote Link to comment Share on other sites More sharing options...
theElevators Posted February 15, 2025 Share Posted February 15, 2025 On Helix Floor, you can use the "10-stomp" mode. If you enable 10-stomp mode on your Helix Floor, you can now reposition all your buttons (except mode and tap/tuner). You can use the left-most buttons for other things and put your up/down buttons somewhere else, so it's more convenient for you. Perhaps you'd want to put your up/down buttons on the top left side, so it's out of the way. To set up what all your buttons do, use the Command Center. CC allows you to map up what all the buttons do, you can mix and match presets/snapshots/stomps. It's extremely versatile. This view is custom for every preset, meaning that if you want to reposition your buttons and have that layout be consistent, you would need to do it in every preset. And also, this view is your "stomp" view. So if you press the mode button and go back into your preset view, you will see the up/down buttons in their usual place. I use the 10-button stomp view myself on my Helix Floor. I simply replicate the familiar layout, but I remove the up/down buttons, they are blank. I do this so that if I'm playing a song that uses all snapshots, I can hit the mode button and the up/down buttons disappear. As a bonus, the same exact hack works for Helix LT, although it was not intended for it. Watch my video to see how I remove the up/down buttons. https://youtu.be/UTQ8wJaXZnc?si=fHRWVLse4_Lq6yQ5 2 Quote Link to comment Share on other sites More sharing options...
kebon29 Posted March 3, 2025 Author Share Posted March 3, 2025 Yeah I'm doing snapshot/stomp with the 10 button on the stomp.What I'm looking to do is possibly moving or removing the Bank switches on the snapshot display. Quote Link to comment Share on other sites More sharing options...
enjalt Posted March 4, 2025 Share Posted March 4, 2025 On 3/4/2025 at 12:25 AM, kebon29 said: Yeah I'm doing snapshot/stomp with the 10 button on the stomp.What I'm looking to do is possibly moving or removing the Bank switches on the snapshot display. Sadly, The 10 switches mode is just available in stomp mode, BUT, with command center you can assign any snapshot on the desired switches. you could stay in stomp mode and assign snapshots on 10 switches mode. It may be the solution you're searching for :) Quote Link to comment Share on other sites More sharing options...
theElevators Posted March 4, 2025 Share Posted March 4, 2025 On 3/3/2025 at 6:25 PM, kebon29 said: Yeah I'm doing snapshot/stomp with the 10 button on the stomp.What I'm looking to do is possibly moving or removing the Bank switches on the snapshot display. If you want to remove the the up/down buttons while still using all 8 snapshots, then you can again accomplish this using the Command Center. Recreate the snapshot layout without up/down buttons, with 10-stomp mode enabled. The video I had posted earlier accomplishes exactly that: If you want to simply always remove up/down buttons everywhere, there is no way to do so. You can use 2 Grolsch washers on each button to make the buttons more difficult to press. Quote Link to comment Share on other sites More sharing options...
