stephenwguitar Posted February 14 Share Posted February 14 Hi all - I want to do something fairly simple - change the level of my drive effect on the fly. The default setting is around 3, and I sometimes need a bit more drive depending on the situation. The problem is - whenever I change the setting and disengage the drive, it reverts back to the default setting. I'm unsure if I actually need to 'save' this - (or if turning the knob should do) but I do a 'save' anyway. This is hugely frustrating as it should be a very simple thing to do. Anyone have any ideas? Thanks in advance :) Model is POD GO - recently updated recent firmware (but had this problem pre-update) Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 15 Share Posted February 15 Are you using snapshots to engage/disengage the drive? If so, look in Global Settings for the Snapshot Edits parameter. 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted February 20 Share Posted February 20 In Pod Go edit, right click on the parameter, select "snapshot assignment". You will see square brackets around the value. Go into a specific snapshot you want to make the change, change the value, save. 1 Quote Link to comment Share on other sites More sharing options...
