richardsugg Posted February 22, 2025 Share Posted February 22, 2025 I can't figure this out. When the stomp is connected to my windows 11 PC (surface pro 9), the volume on the PC maxes out. It blows my eardrums out when I'm wearing headphones. Is there something I can do to make the HX Stomp (or HX Edit) _not_ touch my PC volume? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 22, 2025 Share Posted February 22, 2025 Try Global Settings-> Ins/Outs -> USB In 1/2/Trim. Lower this value until comfortable.This does not adjust your PC volume but lowers the signal level as it enters the Stomp. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 22, 2025 Share Posted February 22, 2025 Not sure what you're saying. HX Edit/HXS does not control the level of the Windows Playback Device. Please provide more detail about your connections and signal chain - Guitar>X>X>X>Speaker. 1 Quote Link to comment Share on other sites More sharing options...
gbr13697 Posted February 24, 2025 Share Posted February 24, 2025 You will almost certainly find that, when you connect your Helix, your Windows sound device changes to Helix from whatever you were using previously. Windows normally has separate volume settings for each device, so the chage in device also results in a change in volume. Go to Windows > Settings > Sound when the Helix is connected, and you should see a list of devices. You can set the default voume of each device independently. 1 Quote Link to comment Share on other sites More sharing options...
Marcelc1000 Posted December 21, 2025 Share Posted December 21, 2025 I experience the same problem. I tried the solution of gbr13697 and set the HX Stomp XL in windows settings on 5(%). But every time I restart my laptop and connect my HX stomp XL it starts at 100%. When I look in the settings default is still on 5%. It is a bit frustrating when I forget tot set it back. Quote Link to comment Share on other sites More sharing options...
