Recent Polyphonic pitch shifting warps/artifacts
thelimey626
Anyone notice that after the latest update, the Polyphonic pitch sounds like total crap? There are heavy digitital artifacts and the semitones "warp" in and out of key. It's so bad that I started using my second guitar again. This is o the Helix LT as well as the Helix Stomp.
Everything that I have in my presets works identically.  Check your cables, a cable crapping out can do all sorts of weird things to your tone/tracking.  I've seen that myself on several occasions.  Also check that you are in fact using the same blocks as before...
After updating to the latest firmware did you perform the recommended Factory Reset, and Restore from Backup, as specified in the 3.80 Release Notes?
Rule 1 - When unexplained weird stuff starts to happen, perform a Factory Reset.
Hope this helps/makes sense.
