kjoiner100 Posted April 19, 2025 Share Posted April 19, 2025 I've had this issue happen more than a few times. I'm practicing with my band and suddenly my Pod Go will go silent. Everything is on, just no output. The only way I've found to resolve it is to turn it off and then back on- not ideal in the middle of a song. It happened again at home. I turned it off and back on which worked for a minute or so and then it went silent again. I turned it off and back on again and the problem went away. I run into FRFRs at home but at practice I run the left (mono) out to a board. It happens either way. I'm running firmware version 2.50 but this has happened on previous versions as well. Has this happened to anyone else? Thanks, Kyle Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 19, 2025 Share Posted April 19, 2025 I suspect a power supply problem. You mention ‘at home’ as distinct from some other place so I doubt it has anything to do with the house/venue power. More likely the POD Go wall wart is failing or there’s an internal circuitry issue. If you can get another power supply I would try that first. Quote Link to comment Share on other sites More sharing options...
theElevators Posted April 28, 2025 Share Posted April 28, 2025 Do you have a volume block in your chain? Maybe you stepped on the pedal switch, and turned yourself down? Quote Link to comment Share on other sites More sharing options...
