steelstringer Posted May 14 Share Posted May 14 Hello! I would like to add a Boss Looper pedal, and I want to double check my thinking. I am using the Helix LT. I am running 2 acoustic guitars (one in the guitar input and the second in the Return 1). I believe the best way to add the looper for guitar 1 is to use Send 1 and Return 2. Is this an acceptable route? YouTube videos suggest the FX loop block to return, but it’s greyed out because I have a guitar in the Return 1 input. Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 14 Share Posted May 14 Maybe use Return 2 for the guitar and free up the FX Loop in Send/Return 1? Quote Link to comment Share on other sites More sharing options...
steelstringer Posted May 14 Author Share Posted May 14 On 5/14/2025 at 7:23 AM, silverhead said: Maybe use Return 2 for the guitar and free up the FX Loop in Send/Return 1? Is there a reason to not use Send 1/Return 2? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 14 Share Posted May 14 Don't know. Never tried it. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 15 Share Posted May 15 On 5/14/2025 at 2:07 PM, steelstringer said: Is there a reason to not use Send 1/Return 2? Hi, Yes - If you’re using Return 1 for the second guitar input, then it would be preferable to use Send/Return 2 as an FX Loop for your external device, plus the option to use the Send/Return as a dedicated FX loop adds the facility of having trails if you are using any external delay, or reverb units. From the manual:- NOTE: Each return can be used only once in a preset. For example, if you add a Return 1 block (or assign one of the input blocks to Return 1), Return 1/2, FX Loop 1, and FX Loop 1/2 items will all appear grayed out in the model list, as they also utilize Return 1. See page 43 of the Helix LT v3.8 Owner’s Manual for more info. https://line6.com/data/6/0a00051afd86673ccb96424d9/application/pdf/Helix LT 3.80 Owner's Manual - English .pdf I have several different brands of dedicated loopers, each with different capabilities, including an old BOSS RC-30 Loop Station. Whichever looper that I choose to use will be patched in on an FX Loop on my Helix, which has the added advantage of having 4 Send/Return jack sockets so I can also run them in full stereo. Hope this helps/makes sense. 1 1 Quote Link to comment Share on other sites More sharing options...
