SunDip Posted June 1 Share Posted June 1 Hey, I am building a pedalboard around my Helix Stomp. I want to power it up using the power adapter attached to my pedalboard (Harley Benton PowerPlant - https://www.thomann.pl/harley_benton_powerplant.htm) I also bought a cable for that which doubles the current from two Power Plant 9V outputs (Voodoo Lab HX Curr. Doubler Adapter PPHX - https://www.thomann.pl/voodoo_lab_hx_curr._doubler_adapter_pphx.htm). Stomp turns on normally but I can't get any sound from it. There is no sound in the headphones either. Once I switch back to the original Power Supply everything works as it should. Whenever I connect it back to the Power Plant the sound is gone. Anybody had a similar problem maybe? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 1 Share Posted June 1 The Powerplant has a hint written on the side: "Max combined current for all 9V DC outputs: 500 mA". The HX Stomp consumes about 900 mA when running. So the Powerplant doesn't provide enough current / power for the Stomp. 2 Quote Link to comment Share on other sites More sharing options...
SunDip Posted June 1 Author Share Posted June 1 Oh I see that all makes sense now, thanks for the help! Quote Link to comment Share on other sites More sharing options...
theElevators Posted June 2 Share Posted June 2 You need one of these: https://voodoolab.com/product/hx-current-doubler-cable/ Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 2 Share Posted June 2 On 6/2/2025 at 12:35 PM, theElevators said: You need one of these: https://voodoolab.com/product/hx-current-doubler-cable/ Hi, If you read through the full post the OP does state: - “I also bought a cable for that which doubles the current from two Power Plant 9V outputs (Voodoo Lab HX Curr. Doubler Adapter PPHX - https://www.thomann.pl/voodoo_lab_hx_curr._doubler_adapter_pphx.htm).” Seems that didn’t work. All 8 outputs of the HB Powerplant when combined can only supply 500mA. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
