bbehrens Posted December 30, 2025 Share Posted December 30, 2025 If you know of any easy ways to view all of the Block assignments at a glance, then put them here. You could easily view all of the block "BYPASS/CONTROLLER ASSIGN"ments in the HX Edit App as there was a panel devoted to it. I could easily see all 23 (just kidding, 2 or 3) blocks that might be assigned to a footswitch. I hope that they include that in the Stadium eventually. 3 Quote Link to comment Share on other sites More sharing options...
Turnbullbass92 Posted February 10 Share Posted February 10 Did you ever figure this out? I can’t find it either! Quote Link to comment Share on other sites More sharing options...
MojoAxe Posted February 11 Share Posted February 11 I’d like to know how to do that as well. Every once I accidentally add an unintentional assignment to a switch which then displays “Multiple” in the scribble strip. I typically just clear the assignments for that switch to get rid of the unwanted assignment and then reassign the desired assignment. It would be nice if I could see a list of the assignments for a switch and then delete any that are unwanted. Maybe that’s already possible now and I just don’t know how to do it? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 11 Share Posted February 11 Anyone who wants to see this feature added can submit a feature request here: https://line6.com/company/contact/productfeedback/ Quote Link to comment Share on other sites More sharing options...
Simbosan Posted July 2 Share Posted July 2 On 2/12/2026 at 2:15 AM, silverhead said: Anyone who wants to see this feature added can submit a feature request here: https://line6.com/company/contact/productfeedback/ It's very hard to manage complex presets without this. Quote Link to comment Share on other sites More sharing options...
bbehrens Posted July 4 Author Share Posted July 4 Yes, ask Line 6 to put in another new Stadium feature that the old Helix had. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted July 5 Share Posted July 5 This has been bugging me too. The thing I'm getting frustrated with, having made all my initial presets when I first got the Stadium with the footswitch assignment set to Auto (why would anyone want that?!) I now want to delete all those footswitch assignments. The quick action methods all seem to be geared towards assigning and not clearing - for example tap the icon on the Home screen and you get a pop-up to do lots of things, including assign a FS, but nothing there to clear it if one is assigned already. If I go to Command Centre, and use the Clear/Reset All function, for some reason it doesn't actually clear Stomp assignments, it only clears the other things I may have assigned, like a Hot Key or Midi Message. The method of touch/holding a footswitch to bring up the Assign pop-up is all well and good, as that does offer a 'Clear Stomp' option, but it means your hands are flying around all over the place - hardly a slick way of operating. Am I missing something - is there simple and quick way to clear a stomp assignment? Quote Link to comment Share on other sites More sharing options...
ryanrosenberg Posted August 25 Share Posted August 25 I have this same problem. For example: I have a switch labeled "Bright". I can't remember what that is assigned too. As far as I can tell there is literally no way to figure that out. I have some switches that ended up as "multiple". Again, no way to figure out what those are tied to. If you bring up the "Assign block" dialog it says "1 assignment" or "2 assignments" etc. in the lower right corner. Clearly all this is tracked. Why can't we just tap right there and see what those assignments are? Another issue: if you turn off capacitive touch, or if you are using foot switch caps that don't support capacitive touch (yes I know some do), then you have no easy way to even bring up the assignment dialog. I fired up the Helix desktop application but, as far as I can tell, there is no way to view or assign foot switches from there either. What is maddening is this was all super easy to handle on my Pod Go where you able to see (and manage) foot switch assignments from one place. It seems to me Line 6 has prioritized assigning buttons on Stadium but not managing them (except making it easy to switch them using capacitive touch). In most ways Stadium is a huge step forward for Line 6 but in the management of button assignments I think it is a step back. Quote Link to comment Share on other sites More sharing options...
henricus1180 Posted August 26 Share Posted August 26 Not sure about 'at a glance', but where you have multiple assignments for a given switch, you can see them all by touching (not pressing) the switch multiple times. Each touch will show a different assignment. Where it controls a parameter rather than a bypass, when it highlights the block, it shows the parameter assignment instead of just highlighting the block. Apologies if I am stating the obvious here, and not exactly answering the question, but I couldn't see that process mentioned in any of the previous comments, so maybe not everyone knows it. Quote Link to comment Share on other sites More sharing options...
maxxlines Posted September 1 Share Posted September 1 On 8/26/2026 at 7:28 PM, henricus1180 said: you can see them all by touching (not pressing) the switch multiple times. Each touch will show a different assignment The problem is that in the OG Helix, everything worked that way. But in Helix Stadium, touching the stomp only shows two of the many assignments. I reported this issue to support. So far, no changes... Quote Link to comment Share on other sites More sharing options...
maxxlines Posted October 15 Share Posted October 15 Well, firmware 1.4 "The Eras Update" is out, and unfortunately... zero fixes for this. Touching the switch still fails to cycle/display all assignments properly on the Stadium UI, and there's still no dedicated panel or list to view bypass/controller assignments like we had in HX Edit on the OG Helix. It's frustrating to see new amps and features added while core UI management bugs and basic feature parity with the old Helix are being ignored. I really hope Line 6 prioritizes this UI fix and brings back proper assignment viewing in the next update. Quote Link to comment Share on other sites More sharing options...
JJMJ Posted 14 hours ago Share Posted 14 hours ago (edited) I'm running 1.4.2 and I don't see a way to list a footswitch's assignments at all. With capacitive touch enabled, I can select, without activating, each block assigned to that switch in sequence - which is not the same as a list. Note that this process of selecting blocks does not translate to the Helix Stadium app and is not reflected there! I personally prefer touch to be off since my unit is on a rack, and I can just touch a block on the display to select it for editing. So, I have to enable capacitive touch whenever I want to retrieve this information. It appears to me that there is no accommodation at all for this in the app. maxxlines provided in a recent post about MIDI footswitch emulation a link to Support for submitting feature requests. Maybe I can add it later to this. I think the UI excels with the exception of these two items. But they are kinda importatnt to some; a real Ouch! Here is the feature request link from the topic mentioned above. https://line6.com/company/contact/productfeedback/ I'm sending this: I would very much like to see the return of a Bypass/Controller Assign tab to the Helix Stadium family, where we can see and edit all Block/Parameter/Source settings in a list view. Thank you. Edited 13 hours ago by JJMJ Adding Feature Request Link Quote Link to comment Share on other sites More sharing options...
