joerch71 Posted January 15 Share Posted January 15 I have connected my stadium XL via S/PDIF out to my RME fireface UCX. I receive a signal, but it's only mono. I have the XLR outputs also connected to my RME interface - here the signal is stereo. Anyone? Quote Link to comment Share on other sites More sharing options...
ReverendLove Posted January 16 Share Posted January 16 How and where did you route to the spdif? Check the setting in in-/oitput settings of the stadium. Quote Link to comment Share on other sites More sharing options...
joerch71 Posted January 16 Author Share Posted January 16 There's signal via S/PDIF that I can receive - I fiddled with the global settings output options to get it working. However, there's no option for mono/stereo - that's why I am surprised that the signal my fireface receives is mono. Quote Link to comment Share on other sites More sharing options...
ReverendLove Posted Friday at 01:40 PM Share Posted Friday at 01:40 PM I can't see any option for this too. I get always a stereo signal. Obfiously it depends where you take the signal from the path if both channels are equal or different. So - no real mono Quote Link to comment Share on other sites More sharing options...
bverdon Posted Monday at 11:40 PM Share Posted Monday at 11:40 PM On 1/15/2026 at 7:06 PM, ReverendLove said: How and where did you route to the spdif? Check the setting in in-/oitput settings of the stadium. Quote Link to comment Share on other sites More sharing options...
ReverendLove Posted Tuesday at 05:24 PM Share Posted Tuesday at 05:24 PM Should be stereo with different channels if you've put stereo modules right of the amp nodule. But here and in the Facebook groups are reports of misbehaving SPDIF outputs. I use SPDIF only splitted from the other path at the beginning to have a clean recording of my instrument. The output is stereo with two identical channels. This is what I expect. Quote Link to comment Share on other sites More sharing options...
joerch71 Posted Tuesday at 06:19 PM Author Share Posted Tuesday at 06:19 PM Yes, I could trace it down. I have had ugly dropouts with the S/PDIF output - at times it was totally quiet and then the sound came back, but was ugly ... sync problems I guess, or internal DSP problems. But once it was back, it was in stereo. It seems that there are a lot of bugs Line6 have to work on. Once everything works, I am planning to use S/PDIF to record the guitar DI and XLR to record the master out. I might also try and look for an output configuration in which I have the amp after the cab as a mono output, the stereo effects as an extra stereo output and the DI. Quote Link to comment Share on other sites More sharing options...
jiml6 Posted Tuesday at 10:30 PM Share Posted Tuesday at 10:30 PM S/PDIF is stereo by default. Make sure there are no mono blocks in your signal path. Quote Link to comment Share on other sites More sharing options...
jpdennis Posted Tuesday at 11:54 PM Share Posted Tuesday at 11:54 PM On 1/20/2026 at 2:30 PM, jiml6 said: S/PDIF is stereo by default. Make sure there are no mono blocks in your signal path. Thank you for the reminder. I did forget about that! Quote Link to comment Share on other sites More sharing options...
