Wifi Connectivity AFTER the update to 1.2.1
bbehrens
The Stadium App still disconnects from the Stadium Unit over my Wifi every once in a while. It finds the Stadium and connects just fine when I initially start the Stadium App. However, when the Stadium App loses connectivity with the Stadium Unit and I try to connect the Stadium in the Stadium App, I get the message that the App successfully updated to 1.2.1 and the Stadium App will simply not find and connect to the Stadium. However, if I close the Stadium App and restart it again - "Vwalah!" (That's my word) and it connects just fine again.
Anyone else having this problem after the update?
Okay. I figured it out. WIERD, but I figured it out. I now see that the Stadium XL is connected via USB (USB icon) and the Stadium is connected via Wifi (Network icon). Line 6 has never been perfect at naming consistency!
bbehrens,
Are you saying you have the Stadium connected to your system via usb-c at the same time you are connecting via wi-fi?  Thanks for any clarification.
jpd
Yes. USB for Audio and WiFi for Stadium App editing. I have been using the Stadium App since the release of v1.2.1 to see what issues still persist and to see if I can re-create them. So far, v1.2.1 looks a lot better than v 1.2.0. But there are still bugs that I have run across. Mainly with Preset/Snapshot state.
  • Thanks 1
  • 1 month later...
I have had the same issue,  but I think I've figured it out at least for my system.   I;m  hard wired CAT6 to my router and Stadium is over wifi.  connects fine for a few seconds.  annoying I know.    But I did something different last night  I'm still hardwired to my router, but I also connect my PC via WIFI,  test drove the Staidium All night... Vwala!!!!!  Still connected.  This may not work for everyone.. but it works for me.
Hi guys! Just found one strange thing - Stadium allows to use cyrillic symbols in the songs list, but after disconnecting from Helix stadium app it won't connect wia wifi until I change the song names back to English (on the unit song screen) and reboot the device.
Maybe someone  finds this message and it can help someone
I don’t know whether this is the cause of your problem.
However, connection drops are often triggered by enabled power‑saving features.
This applies to built‑in Wi‑Fi adapters, USB Wi‑Fi sticks, and many LAN adapters.
On Windows 10 and Windows 11, you can find the relevant settings in the Device Manager.
Select your network adapters, open the Properties dialog, and review the power‑related options.
Some adapters provide a dedicated “Power Management” tab, while others list the setting under “Details.”
If you are unsure which parameter is responsible, the trusted AI of your choice can help you locate the correct option.
Similar issues can also occur with USB connections when Windows temporarily disables them to save energy.
t-ario,
Thanks.  Here is an earlier thread with some pictures and direction relating to your comment as well.
jpd
