Snapshot question
Nyamar
In the same preset I have 2 amps and 2 cabs. Marshall Silver Jubilee + 4x12 V30 Cab and Fender Twin Reverb with 2x12 Twin Cab.
In the Snapshot 1, I want only the Fender stuff, so I turn off Marshall stuff. That's perfect.
Then I go to Snapshot 2, and I turn off Fender stuff, and turn on Marshall stuff.
When I go back to Snapshot 1, Silver Jubilee keeps on, and 4x12 V3- turns off. Fender stuff is never turn on.
If I go back to Snapshot 2, Silver Jubilee keeps on, and 4x12 V30 turns on again.
So, for some reason, I`m not getting the behavior that I need. Any idea what I`m doing wrong?
Do you use any stomp buttons at all or purely snapshots?
I would just clear the bypass assignment for the amp/blocks entirely.  Then assign the bypass to snapshot only.  Then select snapshot 1, turn things on/off as needed, save.  Then go to snapshot 2, do the same and save.
Sometimes the bypass assignments get confused when you have multiple things controlling what is on/off.
Hard to tell without seeing the actual preset, but the way I do that is to put each amp/cab in its own split and use the A/B split type to control which set gets the signal. Thus, no worries about what's ON or OFF.
