Audio Midi setup help on Mac
jesuscares
I'm having trouble setting up Stadium with Logic as I dont see it listed on the devices.I do see a Helix listed in the Audio Midi setup (probably when I use it with my older Helix) in my Mac but it is not highlighted.Maybe I need to configure it there first & I'm not sure how to do it.
I didnt find videos or any help from the manual on this.
BTW I'm able to connect Stadium to the Stadium editor app on my Mac without an issue!
Can someone here help?
Thanks
On 4/20/2026 at 1:39 PM, jesuscares said:
Thanks
jesuscares,
If I am understanding your question, you should see the "ASIO Stadium" as a selection from the ASIO dropdown.  As you probably already know, you will use Logic's external midi tracks to send the commands for preset/snapshot control.  For connectivity use the USB-C on your mac to the USB-C on the Stadium.  I am not a Mac expert so the way the drivers get installed from the Line 6 Stadium App is beyond me.  You might want to open a ticket with Line 6 if you are truly having a Stadium ASIO driver issue.
Compatible OS: Mac OS X, macOS Big Sur, macOS Catalina, macOS Monterey, macOS Sequoia, macOS Sonoma, macOS Tahoe, macOS Ventura
And what I did is completely uninstall and & all OG Helix software with the exception of Helix Native.  I found having a clean system works best for me.
jpd
On 4/22/2026 at 7:59 PM, jpdennis said:
jesuscares,
jpd
Thanks a lot.I updated to the latest firmware just now & I am now able to use it as an interface with Logic Pro.However I'm unable to view Stadium on the plugin list.I see my old Helix Native listed though.Isn't Stadium supposed to show up as a plugin in the plugin list?
@jesuscares,
From what I have gleaned since the Stadium release there isn't a Helix Stadium Native plug-in (yet).  I just use the Helix Native plug-in and it does work for now.
jpd
