chandracly Posted May 6 Share Posted May 6 Here is my setup to reproduce the issue: - Pedal 1: Unity 6 (Channel 16) - Pedal 2: Jackson Audio Broken Arrow (Channel 1) - Pedal 3: HX One (Channel 4) Button 1 Configuration: - Message 1: Channel 1 > Press > CC > Number 2 > Value 0 (Pedal 2 Boost) - Message 2: Channel 1 > Press > CC > Number 1 > Value 0 (Pedal 2 Drive) Expected Behavior: Button 1 should only control Pedal 2 (Jackson Audio Broken Arrow). Actual Behavior: Button 1 also emulates an ON/OFF switch on the HX One (which uses CC 1), despite the HX One being set to Channel 4. Anyone has similar issue? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 6 Share Posted May 6 Not sure this is relevant but here’s a snippet from the manual: “Note that MIDI OUT/THRU is always sent on Channel 1.” Quote Link to comment Share on other sites More sharing options...
chandracly Posted May 6 Author Share Posted May 6 On 5/6/2026 at 2:17 PM, silverhead said: Not sure this is relevant but here’s a snippet from the manual: “Note that MIDI OUT/THRU is always sent on Channel 1.” I dont use the MIDI Out from the HX One Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 7 Share Posted May 7 What MIDI Controller are you using? Have you used a MIDI Monitor to verify that it is actually sending what you think it is sending? Quote Link to comment Share on other sites More sharing options...
chandracly Posted May 7 Author Share Posted May 7 On 5/6/2026 at 5:25 PM, rd2rk said: What MIDI Controller are you using? Have you used a MIDI Monitor to verify that it is actually sending what you think it is sending? I’m using Unity6 by Jet Pedals. I’ve discovered an issue: I can’t connect the HX ONE to the last device in my MIDI chain. When I receive too many MIDI signals simultaneously, it starts listening to random CC values. However, it works perfectly when I place it at the beginning of my MIDI chain. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 7 Share Posted May 7 I'd like to help you, but I can't help if you ignore my questions. Have you used a MIDI Monitor to verify that your MIDI Controller (Unity6) it is actually sending what you think it is sending? 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 7 Share Posted May 7 I've had a quick look at the Broken Arrow and the Unity6 product pages. It looks like you need one of these: Amazon.com: Cable Matters 5-PIN DIN MIDI Splitter Cable (Dual MIDI Cable) - 0.5 Meters / 1.6 Feet : Musical Instruments Connect the single DIN to the UNITY6 MIDI OUT and connect one of the Splits to the TRS adapter cable going to the Broken Arrow and the other to the HX ONE. If the UNITY6 is sending HX ONE commands on Channel 4 and the HX ONE is configured to listen on Channel 4, then it should work. Likewise for the Broken Arrow on Channel 1. Quote Link to comment Share on other sites More sharing options...
chandracly Posted May 7 Author Share Posted May 7 On 5/7/2026 at 8:59 AM, rd2rk said: I'd like to help you, but I can't help if you ignore my questions. Have you used a MIDI Monitor to verify that your MIDI Controller (Unity6) it is actually sending what you think it is sending? Sorry about that, no I don't, but by swapping the chain solved the issue. Now I put the HC One at the beginning of my MIDI Chain and works as expected. Quote Link to comment Share on other sites More sharing options...
