HansBo Posted August 5 Share Posted August 5 Only app is updated and cant update the device?? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 5 Share Posted August 5 Yes. The app update is to provide file transfer compatibility with the newly released Helix Stadium Native plugin. There is no update required to the Stadium firmware. 1 Quote Link to comment Share on other sites More sharing options...
bbehrens Posted August 5 Share Posted August 5 They USUALLY are updated together, but minor version one off's like this are not unusual. Quote Link to comment Share on other sites More sharing options...
HansBo Posted August 6 Author Share Posted August 6 Ok, thanks Quote Link to comment Share on other sites More sharing options...
jpdennis Posted August 6 Share Posted August 6 Just for grins, reading the whole info block discussed what 1.3.3 does address, I discovered once I read the whole list in the latest 1.3.3 upgrade section. It actually went with a blow by blow (forgive me Jeff) ************************************************************* Improvements/Bug Fixes in 1.3 Numerous improvements and many, many bug fixes Improvements/Bug Fixes in 1.3.2 Additional bug fixes Improvements/Bug Fixes in 1.3.3 Support for Helix Stadium Native presets Additional bug fixes ************************************************************* Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 6 Share Posted August 6 Helix app says there is an update for 1.3.3 firmware, and insists I connect HXL via usb, but nothin's happening. Is there a problem ? Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 6 Share Posted August 6 Turned off WiFi, plugged in USB, firmware downloaded, start firmware flash to be told 'Error starting updtate.....Something went wrong...Response:-3' Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 6 Share Posted August 6 On 8/6/2026 at 11:11 AM, Twopods said: Helix app says there is an update for 1.3.3 firmware, and insists I connect HXL via usb, but nothin's happening. Is there a problem ? There is no v1.3.3 firmware update. It's only the app. My app is updated to v1.3.3 and it is not alerting me to a firmware update. Quote Link to comment Share on other sites More sharing options...
jmbachtarzi Posted August 6 Share Posted August 6 Hi, I updated the app to 1.3.3 and no firmware update was proposed ... maybe in the next days Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 6 Share Posted August 6 On 8/6/2026 at 5:42 PM, jmbachtarzi said: Hi, I updated the app to 1.3.3 and no firmware update was proposed ... maybe in the next days There may well be a firmware update in the next few days, as there could always be. But it would have nothing to do with v1.3.3 of the app. That was released solely for preset interoperability with the initial release of Helix Stadium Native. It does not require a firmware update. 1 Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 7 Share Posted August 7 My bad. It was 1.3.2 Apart from the version everything above is what's happening Still no joy. Everything same as above. XL says "Line6 server not available, check internet connection" when I try to log the unit in, but it's online. ~ Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 7 Share Posted August 7 If I understand the situation now your device is running some version of firmware earlier than v1.3.2 and you are being alerted by the app that a firmware update is available. I’m not sure what version of the app is alerting you but perhaps you can avoid the app entirely by updating directly on the device. Press the Main Menu button on the device. There is a Download icon in the main menu that should show that an update is available. Press that icon to initiate the download directly, bypassing your computer and the app. The download should proceed directly from the Line 6 website using only your router’s wifi connection to the Stadium device. 1 Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 7 Share Posted August 7 Hi, thanks for your help, but no can do. XL immediately tells me Line6 server isn't available when I try to get it logged in. Hence download button is "unlit" (if you know what I mean ?) Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 7 Share Posted August 7 Is the XL successfully connected to your local wifi network/router? You should be able to use the WiFi button in the Main Menu to do that. Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 7 Share Posted August 7 yes, full internet access it says Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 7 Share Posted August 7 Time to open a support ticket. 1 Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 8 Share Posted August 8 Thanks Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 11 Share Posted August 11 Support pointed me towards the recently released Helix Central, which sorted everything out. All good now. Thanks Quote Link to comment Share on other sites More sharing options...
Twopods Posted August 11 Share Posted August 11 That would be Line6 Central....NOT Helix Central. Doh ! Quote Link to comment Share on other sites More sharing options...
