SOLVED: Boot Failure, ENTERED UPDATE MODE
langloisbrandon
I spent about eight hours fixing this, and if you follow these steps you won’t have to panic like I did. I bought my Helix a few days ago, tried updating the firmware, and the update got interrupted. After that, the Helix wouldn’t show up on my computer at all — not in HX Edit, not in Line 6 Updater. I thought I’d have to take it back to the shop, but I figured out what actually causes the problem.
When a Helix firmware update gets interrupted, the internal processors can get corrupted. Once that happens, Windows won’t recognize the Helix even if the cable is fine. People will tell you to try different USB ports or different cables, but the truth is the stock Helix cable is usually the best one. The real issue is that you need to create the right environment so Windows can detect the Helix again and let Line 6 Updater talk to it.
Modern Windows has built‑in device protection that can block a corrupted device from reconnecting. So even though the Helix was just working, once the firmware gets corrupted, Windows basically refuses to enumerate it. That’s why it disappears from Device Manager and HX Edit. The fix is getting the Helix into a mode Windows will accept, so the updater can reinstall the firmware cleanly.
1.       ERASE ALL YOUR SOFTWARE AND DRIVERS
A)      SETTINGS > APPS > INSTALLED APPS
B)      SEACH FOR LINE 6 – UNINSTALL ALL DRIVERS AND HELIX STUFF
2.
A) RIGHT CLICK START MENU > SELECT DEVICE MANAGER
B) IMPORTANT: SELECT VIEW > SHOW HIDDEN DEVICES(MAKE SURE CHECKMARK IS BESIDE IT). YOU ARE GOING TO HAVE TO GO THROUGH EVERY SECTION I.E., AUDIO INPUTS AND OUTPUTS, MIDI ENDPOINTS, LINE 6, SOFTWARE COMPONENTS, SOFTWARE DEVICES, SOUND, VIDEO AND GAME CONTROLLERS, UNIVERSAL SERIAL BUS CONTROLLERS.
GO THROUGH EVERY SINGLE ONE AND DELETE EVERYTHING THAT SAYS LINE 6 HELX. I WOULD HONESTLY JUST DELETE ALL LINE 6 STUFF.
3. SOFTWARE
A) Go to https://line6.com/software/
B) Select EXACTLY WHAT YOU USE Helix LT or HELIX or HELIX RACK ETC.
C) Download the TOP SELECTION and download >> LINE 6 UPDATER, DRIVERS, FIRMWARE, HX EDIT
NOTE: IF YOU GET THIS ERROR WHILW INSTALL DO NOT WORRY IT’S A GOOD SIGN CLICK CANCEL AND CONTINUE INSTALL.
C)      Install Line 6 Driver2_5 Helix v2.00.0.0 Installer.exe, then LINE 6 Updater, then HX EDIT. The firmware file will be used in a bit.
5. This is a REALLY IMPORTANT STEP. Go INTO WINDOWS SETTINGS >> PRIVACY AND SECURITY >> DEVICE DEVICE SECURITY >> CORE ISOLATION DETAILS
TURN OFF MEMORY INTEGRITY>> LOCAL SEC. AUTH. PROTECTION, MICTOSOFT VUL. DRIVER BLOCKLIST
Now open Lline 6 updater and you should see your Helix NOW
IF NOT WAIT, If its still not showing up MAKE SURE YOU KEEP ALL THE CORE ISOLATION STUFF OFF AND YOU RUN THE LINE 6 UPDATER INSTALL AGAIN.
6. Proceed to install the NEW FIRMWARE again. Make sure your power wsettings and screensvers are off!
It is a well documented fact that the Line 6 Updater cannot connect to a Helix in a failed state, if HX Edit is also open in the background.
A search through the threads in here should have revealed this information (link below), which also contains a link to how to recover your unit from the “Boot Failure” situation.
Sadly, the Admin of this forum never pinned the article regarding this issue, which was compiled and provided by many long time users and contributors in here.
Hope this helps/makes sense - for anyone else who may encounter this problem.
If you actually READ the article I posted it so someone out there would see it and wouldnt have to bring their Helix BACK or spend HOURS in circles not fixing anything.
YES! "t is a well documented fact that the Line 6 Updater cannot connect to a Helix in a failed state, if HX Edit is also open in the background." Clearly! Thank you for also pointing out POINTLESS DETAILS to waste more of someone else's time.
If you had read THE POINT OF THE ARTICLE! It says that when your HELIX IS IN A FAILED STATE YOUR COMPUTER WILL NOT ALLOW THE HELIX TO SHOW UP UNTIL YOU TURN OFF MEMORY INTEGRITY, AND CORE ISOLATION.
Computers have software built in now to make it harder to do things like BRUTE FORCE PASSWORDs with devices and when you install new firmware the device and computer HANDSHAKE IS CURROPTED NOW. So IT WILL NOT SHOW UP NO MATTER WHAT YOU DO. Line 6 ALSO HAS THESE PROTECTIONS TO STOP PEOPLE FROM MESSING WITH THERE PRODUCTS...
If Memory Integrity was ON → the DFU driver was blocked → Helix never enumerated → “computer doesn’t see it
The MAIN points are this. Most of that article are just extra things they MAY fix an easy problem that may be occuring that DISABLLING MEM INEG will not. But I DONT SEE ANYBODY ANYWHERE POSTING THAT! So I did.
Also in my experience, you can only revive the Helix using a PC.
I crashed my Helix LT when I restored a Set List.  That failed and the Helix stopped responding.  Never doing that again.  Restoring full backups or individual presets never caused issues.
