Helix Stadium Native program change
andresmunozau
Has anyone figured out how to change programs via MIDI? I'm using a MC8 PRO controller and I've been able to control snapshots, and use expression pedals, however, I have not been able to send a program change,or bank changes.
I'm running Helix Stadium Native v1.3.3.1 on Ableton 12 or Reaper
Thanks in advance
The Helix Stadium Native manual contains this statement:
Helix Stadium Native responds to traditional MIDI CC messages from an external MIDI controller device (or MIDI software) to provide remote control of its parameters and snapshots.
That implies to me that MIDI PC or Bank Change commands are not supported.
VST3 is not (simply to users) compatible with MIDI PC Messages.
In Reaper you can save the preset using the "+" icon in the plugin header. It will then appear in the header's dropdown list.
The order of appearance determines the PC# required to call it up, and the order can be changed using that same icon.
I can explain in more detail if you can't get it to work.
AFAICT it is not possible in Ableton.
To clarify:
You said you use Reaper. You CAN use MIDI for program changes in Reaper. It's not really that difficult.
IF you also use Ableton, for instance, for playing Clips, you CAN route and control Ableton from Reaper using Rearoute.
I can explain how to do ALL of the above if you actually want to do what you say you want to do.
OR you could get a copy of ProTools and use AAX.
OR you could switch from PC to MAC and use Logic.
That VST3 is not DIRECTLY MIDI PC compatible is on Steinberg, not Line 6.
On 8/13/2026 at 6:31 AM, andresmunozau said:
Even program change withing the same bank would be acceptable.
I'm not sure what you mean by this. AFAICT there's folders - FACTORY and USER. Setlists imported from OG Helix Native or Helix HW simply place the setlist into the USER folder as a new subfolder containing it's presets, but it is not a separate "Bank".
Oh I didn't know this was not on Line 6.
re: Banks reference:
This is coming from my Helix LT usage. Let me explain. Each Setlist in the hardware is really a Bank (1-7 on Helix LT) and the order of appearance is the bank order, same as presets. On ableton, with regular Helix Native (not stadium), you can switch presets within the same bank, but not banks (AKA Playlists).. so as long as you have the plugin on the appropriate playlist, you can switch presets.
I can also see that Native Stadium sorts preset alphabetically, so, to keep things consistent, one would need to put a number at the start of the preset name, which is workable.
Now, Reaper or Ableton. I use both, Reaper for mixing and mastering, Ableton for production. BUT, I use Ableton in our band, as it played nicely with the rest of the software and hardware we use. My intention is to replace my Helix LT with Native Stadium. I suppose I could have a single preset with all the stuff as a virtual pedal board and turn on/off stuff using MIDI CC or snapshots, that is also a workable option.
I meant that Line 6 is not responsible for the changes from VST2 to VST3. That's ON Steinberger.
I'm wondering how you are doing this, as the Pilot's guide says you can't, except, as I previously noted, by using AAX (ProTools) or AU (MAC/Logic etc):
Setlist, Preset, and Snapshot Recall via MIDI
NOTE - AU and AAX Plug-in Formats Only: At this time, remote MIDI control of setlist and preset changes is supported only with the AU (Mac) and Pro Tools AAX (Mac and Windows) Helix Native plug-in formats. It is not supported for the VST2 or VST3 Helix Native plug-in formats on Mac or Windows. Also note that Setlist and Preset changes performed via MIDI PC/CC messages are not supported by Undo, and will clear the current Undo history - please see “Undo and Redo” on page 27.
Are you using Ableton on a MAC? I just noticed that you didn't specify, so I ASSUMED (silly me!) that you were using Windows.
Again, this is simple in Reaper, with Helix OR Stadium Native, I just can't see a practical method for doing it in Ableton with VSTs.
