TallanLatz1 Posted August 16 Share Posted August 16 Hello!! apologies if this has already been asked about; I just haven’t seen. so I’ve had my stadium for about 7 months give or take. Absolutely LOVE it, I noticed when I played Friday night for the start of our set. I started with a guitar I normally don’t play with and when I plugged it in to get rocking the tuner STOPPED working and when I took it off the tuner it was giving me some crackling sounds. I switched guitars and it went away, but the tuner still isn’t working. I plug it into instrument 1 and the presets work just not the tuner. I do use this for bass and guitar gigs. I’m mainly a guitar player but occasionally fill in on bass. I have to plug into instrument 2 in order for the tuner to work. any advice on how to fix this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 16 Share Posted August 16 The Tuner ‘listens’ only to the physical input(s) to which it assigned using the Tuner Input parameter. Make sure the Input parameter matches the physical input you are using. Quote Link to comment Share on other sites More sharing options...
TallanLatz1 Posted August 17 Author Share Posted August 17 I made no adjustments to the parameters. I literally turn it on, move it to the setting/preset that I’ve had since January and it’s never done this to me before. I’m usually able to just plug in, tune and then start the show. now I have to plug it into instrument 2 in order for me to get signal to the tuner. If I plug it back into one the tuner doesn’t work but when I exit the tuner screen the rest of the signal works. Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 17 Share Posted August 17 So what happens if you do adjust the parameter? Quote Link to comment Share on other sites More sharing options...
TallanLatz1 Posted August 17 Author Share Posted August 17 I fixed it, under the tuner the first knob above the switches was moved to instrument 2, so I must have accidentally kicked it or bumped it to cause it to switch to instrument 2. but it is fixed now. so I guess if this happens again that’s the first spot I should check! Quote Link to comment Share on other sites More sharing options...
boynigel Posted August 26 Share Posted August 26 i've had my tuner fail twice now in the two months i've had my XL. basically what happens is it stops recognizing notes. i'll pluck my B string, and it'll register as a G or some other unrelated note. This happens on all strings while in strobe mode. i didn't switch tuner types to see if the problem went away. if it happens again, i will try. the last time it happened was at my gig last friday. had to plug into my bassist's tuner! Quote Link to comment Share on other sites More sharing options...
