boynigel Posted 6 hours ago Share Posted 6 hours ago If the manual gives a value or suggestion, shoot me- because i can't find any such info in there. I've been running everything at -6.0, that way i have somewhere to go volume-wise, if need be, but i'm wondering if it's recommended to be closer to 0.0 for any reason? Quote Link to comment Share on other sites More sharing options...
silverhead Posted 6 hours ago Share Posted 6 hours ago There’s an industry standard called ‘unity gain’ which I believe represents a standard input/output signal level strength. I think devices are built to accept this level of input and send this level of output at some default setting. No idea if my layman’s understanding is correct or what the definition is in physical terms. I would welcome more informed insights on this, expressed without needing an understanding of physics. i.e. no mention of loudness metering or a need for knowledge of what a ‘db’ is. I believe Line 6 products are built to send unity gain output when the Volume knob is maxed. I think this also minimizes the signal-to-noise ratio in the signal meaning the signal is cleaner. So theoretically when the Vol knob is maxed the external mixer or PA receives the ‘ideal’ signal strength with minimal noise. Again, theoretically, if the Vol knob is less than max the person operating the mixer/PA may have to adjust the Input Trim setting to compensate for the less-than-unity gain incoming signal. But frankly I’ve never heard any difference in the end result if the Vol knob is not maxed out. Quote Link to comment Share on other sites More sharing options...
theElevators Posted 3 hours ago Share Posted 3 hours ago It's simple. Set your output level to "microphone" for XLRs. These go to your FOH. The whole point of these Left/Right signals is they do not change, because otherwise you would be overriding what the sound guy is running for your guitar. So set up your volume knob to not affect the XLR volume, only 1/4" outputs. Also--no Global EQ should be applied to XLRs. That's the rule of how the processor should be run. XLRs go to FOH. 1/4" go to your FRFR .... or in my case to a power amp + guitar cab. You use the volume knob to adjust your on-stage volume. If the stage is too boomy, I apply the Global EQ to the 1/4" only. I do not create any additional output path where the amp/cab sim are bypassed. Just the same exact signal always goes to "multi". I've been doing it this way and have not had any complaints. When building your presets, the fully-loaded preset with actual blocks should be about as loud as the blank "New Preset" preset. If it's slightly different it's not a problem. So when building it, toggle back and forth and check if your preset is louder/softer than the blank preset and make adjustments. No need for any exact measurements, just use your ear. That's all there is to it. Quote Link to comment Share on other sites More sharing options...
