Are The Original Hd500 Preset Setlists Around Anywhere?
smrybacki
I happen to have them.
Awesome my man - I needed these too! I finally picked up a used HD500 and the guy had blanked every preset except one :-)
I wanted to at least hear the factory ones.
+1 for the win!
Hi
I appreciate I am highj-acking this thread but I have only had the HD500 about a week but I cannot seem to navigate around the user presets and set lists etc without having to connect my laptop and use the HD 500 Edit . Is that normal as I cant see anyway of navigating as it seems if I am in SET LIST 1 for example I can switch between only those patches only and not bank up or down into the other set lits or fixed presets via the pedal board or the Home screen ?
Help?
Apologies in advance if I am being thick
All the best
G
Hi
Help?
All the best
G
Single push the control that sticks up on the left side. That brings up the setlists. Use the same control (by turning it either way), or use the arrow pad control on the right side, to highlight the setlist you want. Then hit the enter key on the right side. Then single push the control on the left side again (the view button works also).
