BigChas52 Posted October 17, 2013 Share Posted October 17, 2013 Get rid of ASIO4All and use the Line 6 ASIO driver. Quote Link to comment Share on other sites More sharing options...
svenklerkx Posted May 27, 2014 Author Share Posted May 27, 2014 Hello, I have asio4all for my DAW and when I open FL studio with my HD POD PRO enabled in my asio4all it makes my DAW lag really hard. It's like its stuttering. (0,5sec sound then 0,5sec no sound) I can't get it to work with my HD POD but when I disable it, FL works fine. I searched all over the internet but I can't find an answer anywhere. Please help me Greetings, Sven. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 27, 2014 Share Posted May 27, 2014 ASIO4ALL is not supported, use monkey and get the Line6 ASIO drivers. Quote Link to comment Share on other sites More sharing options...
svenklerkx Posted May 27, 2014 Author Share Posted May 27, 2014 The thing is, I just bought a new pc, before I had VISTA. That computer was an ancient piece of trash but it worked, now I got a new PC with the same soundcar (us-122mkII) and the same POD but now it doesn't work. I used monkey to update everything but nowhere in Line 6 monkey does it say anything about ASIO so I don´t know the best place to get it. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 27, 2014 Share Posted May 27, 2014 yeah it wont say ASIO should just say drivers. you might try googling slimdrivers, run that it may find some missed driver updates that could affect performance. Quote Link to comment Share on other sites More sharing options...
svenklerkx Posted May 27, 2014 Author Share Posted May 27, 2014 Slimdriver says all my drivers are up to date now and after restarting nothing has changed. If you had Windows 7 64bit HD pod pro with an external sound card how would you set it up to work? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 27, 2014 Share Posted May 27, 2014 I had the same setup, I used the SPDIF out into the other interface... but that depends on your interface.... Quote Link to comment Share on other sites More sharing options...
FlyingsCool Posted May 27, 2014 Share Posted May 27, 2014 The first thing I would do is remove ASIO4All. When I had it installed on my Windows 7 machine, it screwed up my access to the Line 6 ASIO driver, and another ASIO driver (I just wanted to test it to see what it was all about). After doing some research, as far as I understand, AISO4All does not support even Vista, much less Windows 7 or Windows 8. It was written for XP. So I uninstalled it, and everything started working again. After uninstalling ASIO4All, connect your POD to your PC USB port. Turn on your POD, Start POD HD Edit. Make sure POD HD Edit can connect to your POD. Start FL. Look for the ASIO POD HD driver under available interfaces. If you don't see it, there is something wrong with your installation. It should just be there. I'd uninstall all your POD software and start over with the installation process. Quote Link to comment Share on other sites More sharing options...
lachinelli Posted May 27, 2014 Share Posted May 27, 2014 ASIO4ALL are ASIO drivers meant for regular soundcards without native ASIO drivers. The POD is an interface itself with native ASIO drivers, therefore you don't need to use ASIO4ALL at all (When using the POD of course). What you should do is let Monkey install latest Line 6 ASIO drivers and after opening FL choose Line 6 ASIO driver in the Sound Options. Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted May 27, 2014 Share Posted May 27, 2014 The newer PC's all come with USB 3 ports. Line 6 stuff doesn't like USB 3. Make sure you are plugging into a USB 2.0 port. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted May 28, 2014 Share Posted May 28, 2014 Am I the only person that thought he was having trouble in Florida? 1 Quote Link to comment Share on other sites More sharing options...
FlyingsCool Posted May 28, 2014 Share Posted May 28, 2014 The newer PC's all come with USB 3 ports. Line 6 stuff doesn't like USB 3. Make sure you are plugging into a USB 2.0 port. Decent point, and definitely something to check, but this is not universally true. My POD HD Desktop works fine on my HP 8560w Elitebook Laptop USB 3.0 ports. It uses Renesas Electronics USB 3.0 Controller and Root Hub. Am I the only person that thought he was having trouble in Florida? Nope, me, too.... Quote Link to comment Share on other sites More sharing options...
svenklerkx Posted May 31, 2014 Author Share Posted May 31, 2014 Hey all, Been looking for hours finding a Line 6 Asio driver for my HD pod pro, could not find it anywhere. Can anyone please send a direct link of what I need because I`m done searching and trying for days without results. In my DAW it lists ASIO POD HD Pro, but I´m not sure if that´s the one I need. When I start FL it says: "Not enough ASIO output channels available, at least 2 channels are needed." (it says that twice) I can't select an output when I choose the ASIO POD HD Pro driver so I'm pretty sure it's not the 1 I need. Thanks in advance, Greetings, Sven. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted May 31, 2014 Share Posted May 31, 2014 windows drivers: http://line6.com/software/readeula.html?rid=5598 Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted May 31, 2014 Share Posted May 31, 2014 With ASIO you do not select the output. The output and input device is the same. Make sure that your HD Pro is connected and turned on before running FL Studio. You can also find the latest drivers here http://line6.com/software Quote Link to comment Share on other sites More sharing options...
alienux Posted June 1, 2014 Share Posted June 1, 2014 Am I the only person that thought he was having trouble in Florida? No, and in fact, even though I read this thread the first day it was posted, I didn't realize it wasn't about trouble in Florida until I read your response. Quote Link to comment Share on other sites More sharing options...
