DelphiJuice Posted July 10, 2014 Share Posted July 10, 2014 Hi I've just tried to set UX2 as input and output in Logic, Reaper even for all the sounds in my mac but I hear nothing. If I connect my headphones to my mac it sounds ok (so it's not a headphones problem). If I try to change from 44.100 Hz to 48.000 Hz or higher it clip a while and then it returns to 44.100 Hz. Can you help me? Thanks! :) P.S. The level indicators moves up and down like if signal passes inside but can't go out. My temp headphones are a Sony Hi-fi model (don't insult me), and I have to convert the little jack in a bigger jack to connect. Quote Link to comment Share on other sites More sharing options...
Jazzguitar59 Posted July 10, 2014 Share Posted July 10, 2014 Sounds like you have a problem. Contact me at nevillepearson1@gmx.com. Or call 0786451025. Or wrote to me at 31 Camborne Close Whitleigh Plymouth Devon PL5 4PE (England) Neville 1 Quote Link to comment Share on other sites More sharing options...
psubak Posted September 24, 2015 Share Posted September 24, 2015 When I'm using my UX2 I have a decent pair of Bose headphones, and I'm using a 1/4 inch adapter to plug it into the phones jack, and when I plug it all the way in, the sound is extremely muffled, BUT if I plug it in about 3/4 s of the way in (I find a "sweet spot basically") then I get sound. But this is kind of bothersome. Help? Quote Link to comment Share on other sites More sharing options...
avkurt Posted October 1, 2015 Share Posted October 1, 2015 I lost my guitar in and headphones out after I up dated to El Capitan on my mac. I did all the up dates in Monkey so everything is up to date but would like a fix for this issue with the new OS X thank you Quote Link to comment Share on other sites More sharing options...
phenix9 Posted October 8, 2015 Share Posted October 8, 2015 el capitan is THE problem we must go back to Yosemite or waiting for an update soon Quote Link to comment Share on other sites More sharing options...
heliolagojr Posted June 8, 2020 Share Posted June 8, 2020 On 7/10/2014 at 3:02 PM, DelphiJuice said: Hi I've just tried to set UX2 as input and output in Logic, Reaper even for all the sounds in my mac but I hear nothing. If I connect my headphones to my mac it sounds ok (so it's not a headphones problem). If I try to change from 44.100 Hz to 48.000 Hz or higher it clip a while and then it returns to 44.100 Hz. Can you help me? Thanks! :) P.S. The level indicators moves up and down like if signal passes inside but can't go out. My temp headphones are a Sony Hi-fi model (don't insult me), and I have to convert the little jack in a bigger jack to connect. Did you have any success? I have the same issue. Quote Link to comment Share on other sites More sharing options...
