austinctu24 Posted July 24, 2014 Share Posted July 24, 2014 I'm trying to control the volume on the Octo reverb with the pedal. how do I set this up? Just got a pod after using a M13 for years Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 24, 2014 Share Posted July 24, 2014 In the Signal Flow View, select the Octo, then double-press the MOVE button. The Controller Assign screen is then displayed. Use the Multi-function Knobs 1-4 to select the Volume parameter, assign its controller (EXP1 or EXP2) and define the min/max values. Quote Link to comment Share on other sites More sharing options...
radatats Posted July 24, 2014 Share Posted July 24, 2014 I think you need to use the MIX parameter, there is no VOLUME parameter for the Octo... 1 Quote Link to comment Share on other sites More sharing options...
