madastrota Posted August 23, 2014 Share Posted August 23, 2014 Something is up with the way my wah settings are behaving. I'll have the settings where I want them and once I start using the expression pedal the settings get all wonky. I don't have this problem with the volume pedal or the compression settings. It's only the wah. Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 25, 2014 Share Posted August 25, 2014 Can you give a little more detail on what you mean by "all wonky"? What is happening with the settings? Have you set both the heel and toe parameters on the wah? Are you using manual save or autosave for the effects? Quote Link to comment Share on other sites More sharing options...
madastrota Posted August 25, 2014 Author Share Posted August 25, 2014 In this case, "all wonky" means that when I engage the expression pedal the Position and Mix settings sometimes reset themselves. For instance, I'll have Mix set at 0% heel and 75% toe. Then when I engage, it might reset to something like 10% heel and 40% toe. Again, this is only with the wah pedal and it doesn't matter which one. Quote Link to comment Share on other sites More sharing options...
madastrota Posted August 25, 2014 Author Share Posted August 25, 2014 And I'm using Manual Save, I think. (The one where if I turn it off and back on it saves the last settings that I had.) Quote Link to comment Share on other sites More sharing options...
Tboneous Posted September 1, 2014 Share Posted September 1, 2014 I'm having wah issues too. I can't get the exp 1 toe switch to turn on and off the wah. I am using an ernie ball exp pedal in slot two. What is odd is that I can assign the wah to exp 2 and the exp 1 toe switch will work to turn the wah on and off but the wah is controlled y exp 2. I can't get the wah assigned to exp 1 and have the on and off be the exp 1 toe switch. Quote Link to comment Share on other sites More sharing options...
