Skadus Posted September 1, 2014 Share Posted September 1, 2014 Hi guys! These are very old products and this question might have been answered before (but haven't found an answer): Can I use GearBox as an insert effect in Cubase 6 with a TonePort GX or does the ASIO driver not support it? Cubase offers me the option (see attached), but when I chose it - it freezes. Thanks a lot in advance! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 1, 2014 Share Posted September 1, 2014 gearbox plugin is no longer supported, but using pod farm 1.x should be a free option.. (pod farm 2.x is not a free upgrade) Quote Link to comment Share on other sites More sharing options...
Skadus Posted September 1, 2014 Author Share Posted September 1, 2014 gearbox plugin is no longer supported, but using pod farm 1.x should be a free option.. (pod farm 2.x is not a free upgrade) Hi TheRealZap Thanks a lot for your quick answer. But can I use Pod Farm with the Tone Port GX? Basically what I want to do is monitor the distorted guitar while recording the dry signal in Cubase. I have tried the PRE option in the 3/4 Send (see attached image) while running the standalone version, but for some reason it still records the wet signal. Can you help? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 1, 2014 Share Posted September 1, 2014 the option should exist, i believe that you should see an input 3/4 from the GX/pod farm which would be the dry signal. I'm not 100% sure though because i've been using a different interface for quite a while. Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted September 2, 2014 Share Posted September 2, 2014 Sends 3 & 4 are indeed the dry signal. I like to record 1 & 2 on one track, and 3 & 4 on another. That way if it turns out that 1 & 2 sound perfect, I don't have to tweak 3 & 4 to get the same results. Charlie Quote Link to comment Share on other sites More sharing options...
Skadus Posted September 2, 2014 Author Share Posted September 2, 2014 @ TheRealZap I have downloaded the free trial of Pod Farm 2.5 and it works neatly with the Toneport. I can't use it as an insert effect, but I guess this is a license issue. Can you please confirm? @ BigChas52 Do I understand correctly that I have to use Pod Farm / Gearbox as a plugin in order to use the 1&2 / 3&4 option? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 2, 2014 Share Posted September 2, 2014 if you buy a license for 2.5x it will include access to the plugins. that i can confirm. If you're GX is a blackfaced pod studio model it should have access to the plugins using pod farm 1.x HOWEVER... pod farm 1.x does not have 64 bit plugins... and pod farm 2.x does... so if you're using certain software the 32 bit plugins will not work (or vice versa) not aware of any cubase specific limitations on that... but many other softwares have this issue (the new logic pro x on mac for example... 64bit only...) Quote Link to comment Share on other sites More sharing options...
Skadus Posted September 2, 2014 Author Share Posted September 2, 2014 I am using Windows 8, but I have the 32bit-version of Cubase 6 installed (it's in the Program Files (x86) folder). I have the good old redfaced TonePort GX, but I think it's the same hardware as the POD Studio - I've read you just get different programs with it (as you say). I think I'll give it a shot, $99 for the Pod Farm 2.5 is really not expensive (and maybe there's even a money back guarantee). I have another question ... this is rather for Cubase, so not sure if you can help me. In order to avoid latency issues I have to choose the ASIO TonePort GX as ASIO Driver in Cubase, right (see attached picture)? Can I have an influence on the input and output latency mentioned in the picture? I have an Intel Core i7-4500U and 8GB RAM ... they should be able to handle that? Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted September 2, 2014 Share Posted September 2, 2014 No. You do not use it as a plug in. Use it as an ASIO device. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 2, 2014 Share Posted September 2, 2014 the red-faced models do not come with the plugin license.. that's the primary difference. there is a 30 day money back guarantee. I am using Windows 8, but I have the 32bit-version of Cubase 6 installed (it's in the Program Files (x86) folder). I have the good old redfaced TonePort GX, but I think it's the same hardware as the POD Studio - I've read you just get different programs with it (as you say). I think I'll give it a shot, $99 for the Pod Farm 2.5 is really not expensive (and maybe there's even a money back guarantee). I have another question ... this is rather for Cubase, so not sure if you can help me. In order to avoid latency issues I have to choose the ASIO TonePort GX as ASIO Driver in Cubase, right (see attached picture)? Can I have an influence on the input and output latency mentioned in the picture? I have an Intel Core i7-4500U and 8GB RAM ... they should be able to handle that? Quote Link to comment Share on other sites More sharing options...
