the29band Posted September 8, 2014 Share Posted September 8, 2014 As the subject says, can the HD500 be used to send signal to 2 amps, switch between the 2 amps and/or run them in stereo? Thanks! Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 8, 2014 Share Posted September 8, 2014 Yeah, you could do that. You'd just have to make sure have things panned appropriately for each preset. Quote Link to comment Share on other sites More sharing options...
the29band Posted September 8, 2014 Author Share Posted September 8, 2014 Thanks phil_m. Could you explain how the connections from the HD500 to the amp will look like? Is this HD500 Unbalanced outputs (L and R) to Amp 1 and Amp 2? Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted September 8, 2014 Share Posted September 8, 2014 Yes, that would be the easiest way. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted September 8, 2014 Share Posted September 8, 2014 I use the 1/4 outputs to a pair of Marshall JCM900s and run stereo. Placing a stereo delay on the left send and setting it to 20ms and 100% mix gives a nice stereo widening effect. Also other effects, such as using the gas pedal to pan on the fly from one amp to other is cool to get a dueling solo effect. Live it really freaks people out. You can tell the ones who have had too much too drink when you do this... Quote Link to comment Share on other sites More sharing options...
