mikefarnham Posted September 11, 2014 Share Posted September 11, 2014 Hi everyone. Started to try to input tones on my Vetta 2 combo using my Edirol UA25 and although using Edit; it showed up and I could configure it and an icon of the amp came up BUT I could get no further as on pressing OK I got a could not connect to the device message. So, uninstalled Java umpteen times using umpteen versions and then finally saw sense. Went out and spent £22 on an M Audio Midisport Uno as everyone says that is the answer. Same result. Have checked the amp is on midi channel 1 and tried swapping cables. Amp firmware version 2.03 Digital interface card 1.0 Edit version 3.06 Running windows 7 64bit (have also tried Java 32 bit!!) Well hacked off, very frustrated and totally infuriated. Knew it would be like this. HATE MIDI today more than I did yesterday. Any suggestions gratefully received please. Many thanks, Mike. Quote Link to comment Share on other sites More sharing options...
POsulli634 Posted September 11, 2014 Share Posted September 11, 2014 M-Audio Midisport UNO is really the only interface that consistently works. I bought one when my Vetta 1 crashed. I reflashed using the Uno and Monkey, replaced the internal battery, the process worked pretty flawlessly except that the results were my Vetta 1 was upgraded to a Vetta 2 and the amp only works for about 30 minutes and locks back up, again. No replacement parts for vetta, no service for vetta. Thanks for nothing, Line 6. I hope you appreciated the thousands of dollars I spent with your company. I decided to spend it on a Marshall combo and a new pedal board. Line 6 is in my rear view mirror. Quote Link to comment Share on other sites More sharing options...
mikefarnham Posted September 12, 2014 Author Share Posted September 12, 2014 Just read a note on the 3.00 download section of the Line 6 download page which states that the latest firmware update (2.5) is needed to use the latest version of Edit. Will be interesting to discover how I manage it with my existing hardware. Now looking for version of 2.03 edit for windows - only found one for Mac so far. Anyone have one please? Thanks, Mike. Quote Link to comment Share on other sites More sharing options...
BillBee Posted September 12, 2014 Share Posted September 12, 2014 Hey Mike, When you go here: http://line6.com/software/index.html Be sure to click the archived box when doing the L6 Edit Windows search. Its in the list which will pop up. -B Quote Link to comment Share on other sites More sharing options...
sliding_billy Posted September 13, 2014 Share Posted September 13, 2014 Try sending some midi CCs (things that you can confirm with button light changes) with Midi-OX or SendSX to be sure that it can accept midi signals before pulling your hair out over other conflicts. Quote Link to comment Share on other sites More sharing options...
mikefarnham Posted September 13, 2014 Author Share Posted September 13, 2014 Thanks fellas. Yes Billbee I had gone to the archived downloads BUT had put in Windows 7 so nothing showed. The trick was to put in XP and the old versions of Edit showed and loaded in Windows 7 no trouble. AND Sliding_Billy, you were right about sending some midi dumps to check the in and out cables via the lights. Actually I did that first with my Edirol UA25. Quite easy using Midi Ox. If you are new to this make sure you check the midi inputs in and out show YOUR CURRENT device as the program does not automatically change from your old one if you are chopping and changing them to try to get something to work. Sending the sysex dumps gave me confidence all my hardware was working and, obviously the green lights on the M Audio Uno flash when there is a data transfer. I was a bit dim when I got Edit working not understanding that if you loaded a patch into the editor it was simultaneously loaded into the active Vetta user channel where you can monitor it if you have a guitar connected and just press SAVE twice on the Vetta if you wish to keep it. Instead I was loading a tone in the editor and pressing SEND TO in order to get it to the amp giving me midi overload or some such messages. I think I have backed up my user bank by pressing bulk get with the cursor in the user bank column. This was saved as Vetta2bundle and I created a separate folder for user backups. Oh les beaux jours!! Thanks everyone!! Hope this all helps some other poor devil. It has taken me two days to do what would only have taken a few hours if I had only known - idiot!!! Quote Link to comment Share on other sites More sharing options...
