Ux8 Problem with Yosemite
Some of you have reported that Monkey 1.68 won't open in Yosemite. Here are some questions which may help us reproduce then fix this issue:
-Does this problem happen when a Line 6 device is connected to your mac?
-Does this problem happen when a Line 6 device is not connected to your mac?
-What Line 6 device are you using when this happens?
-Have you completely removed Monkey and any Line 6 drivers (including running the driver uninstaller) and reinstalled Monkey 1.68 and Driver 7.3.7?
-Was your Yosemite installation a clean install or an upgrade?
-What is the model of your mac?  (In the About This Mac screen, send the entire line after the OS version.)
Im still running a 2009 17" Macbook pro with my UX8. (10.6.8). I use the gearbox plugin with garageband (6.0.5) - Now, I understand this is some OLD tech and versions, but everything works reasonably well.
Could someone let me know if it's safe to upgrade to Yosemite and Garageband 10 yet?
I have an issue where i need to do a repair install, but don't have my 10.6 discs, and Yosemite isa free upgrade...
If anyone could take the time to answer this, I would be more than grateful!
Cheers!
  • 3 weeks later...
I have done all that is stated in this post and Monkey still won't open while running Yosemite.  Has there been a solution to this problem?
iMac (24-inch, Early 2009)
2.93 GHz Intel Core 2 Duo
8 GB 1067 MHz DDR3
Thank you for your help
  • 4 months later...
Hi Guys,I
have been following this string of posts a couple of weeks ago and it solved my issues with my Mac and the conflicts with the latest OS.  Out of the blue no signal would get to my interface from the mac.
I upgraded the driver and had the crashing issue and the latest upgrade that I got from this thread seemed to fix it.
My system worked perfectly for a couple of weeks and now it seems to have the same problem that I started with where no signal is going to my interface again.  I have tried re installing the drivers again, but I am having no luck at all with this.
Any ideas?
