				Posts26
Everything posted by nerven
	  Expression pedal reaction question, possible stupid question...?!?nerven replied to themetallikid's topic in Helix I have a ticket open too...the polarity keeps changing on pedal 1 ... pedal 2 seems fine...
	Is it possible to sync two hx fx unit's loopers?
	I would like to use a seprate pedal for the looper too...midi pedal?
	I have this issue too...Any fix?
	Yes, any suggestions? This is the only aspect of the unit I have not explored yet...
	cool...looking forward... Spring is until Jun 21 so I guess we got some time....
	Euripide,did not mean to jack your thread...I think what you want to do is possible as the Y does have a L/R balance control of each path...
	As far as I can tell, there is no mixer at the beginning of the signal path, only at the end. At the beginning you only get a Y option. I have cables plugged in and the mixer at the beginning of the path does not appear. I tried to put the volume block set to 0 after the Y then add the return block as the input, but it created a feedback loop...I've asked support and they seem to think there should be a mixer block at the beginning, just like at the end...but I can't get it to happen. I'm not trying to split Main L/R input, but trying to have the Main L/R on path A and the Return L/R on Path B. But any discrete input path would work for my needs....
	I'd like to know this too... I can assign Path A and B outputs independantly but the input seems to default to only Y.
	1.) I should have used the correct terminology. I was asking if the length of the overdub loop could be multiples of the original loop length vs. stack ? 2x 3x 4x 8x ... 4.) Can 2 HX FX units sync loopers? 5.) Is it possible to use an external foot switch to control the overdub in/out? Thank you for your answers!
	Hoping you guys develop the looper a bit more...
	1.) Does the overdub have to restart after one play of the first loop? Is it possible to keep overdubbing for multiple passes? 2.) Does overdub start as soon as you press or does it wait till the beginning of the first loop? 3.) is there a level threshold to start recording vs press?
	Odd one...but there was a band that performed namm 2006 or around then... in the line6 booth. They were called mule something...it was a dude in a wig and the song was about a girl who stepped on a sugar packet...so he called her sweet shoes...I would like to watch that performance again... if anyone has a link or has any idea what i'm talking about...
	Rest Location & Privacy still not getting input in any apps...Output still works fine though...
	I'm on an iPad 2. It recognizes it at first but then turns off the mic/input. output still works. privacy settings are correct. just no input.
	I can't get a signal from the input anymore but output still works. Any ideas? I'm on iOS 7.0.3
	  Usb Too? Or Just 30 Pin/lightning?nerven replied to steve842's topic in Sonic Port devices / Mobile In bumpidity bump bump
	I would like to use this pack in Mobile POD / Sonic Port. Is this a possible future in app purchase? Mainly I am interested in the string and synth models. Thanks!
	The iPad ran out of juice the other night...It would be nice to charge and use at the same time...
	  Usb Too? Or Just 30 Pin/lightning?nerven replied to steve842's topic in Sonic Port devices / Mobile In maybe this would work? http://www.is-pc-parts.com/female-30pin-to-male-usb-cable-for-iphone-ipad-p-1613.html
	  Usb Too? Or Just 30 Pin/lightning?nerven replied to steve842's topic in Sonic Port devices / Mobile In USB support on OSX should work since the unit is class compliant. no?
