gastric
    8
Everything posted by gastric
  1. This occurs every time when with blocks added from the FAVORITES category. Snapshots never retain the correct bypass state in Native for the blocks added via FAVORITES.
  2. Add another user you just saved after a similar experience. - Migrated from an older Intel Macbook to a M3 Macbook - Used Migration Assistant to move everything over - Reinstalled apps identified as Intel vs Universal/iOS which included all Line6 apps - Authorized my new computer with Line6 License Manager - Might have managed to login to my Line6 account in Helix Native (can't say for sure) - Reaper would immediately crash after that point anytime I opened Helix Native Was mildly annoying but wasn't terribly difficult thanks to your post. I was unable to find any official Line6 instructions on how to do this. I obviously lost my user data along the way. However, I still have the old Macbook I can create a backup. - On old Macbook: Settings > Presets/IR > Export Bundle - On new Macbook: Settings > Presets/IR > Import Bundle And discover my Presets have been imported but none of my IR or Favorites..... Onto my next adventure of exporting > importing all of those manually. And there's no Command+A support to select all, and I didn't name all of my damn IR with the slot name they were saved in so it's a huge PITA getting them all back into the correct place so they map with presets (I vaguely recall that's how they work). My minor annoyances are growing....
  3. Free, though tedious, solution for Intel Mac users. These instructions will NOT work for M1/M2 machines. Writing these directions from memory after just updating an old Spider IV 75 from 1.x to 2.x, hopefully they're accurate. * Install Virtualbox: https://www.virtualbox.org/wiki/Downloads or if you're a Homebrew user `brew install virtualbox` * Download free Windows Virtualbox VM: https://developer.microsoft.com/en-us/windows/downloads/virtual-machines/ * Start Virtualbox and Import the VM, or just double-click the .ovf file that came with the VM download * In the VM Settings > Display > disable 3D Acceleration or the VM likely won't start based on my personal experience * Connect your Floorboard to your Mac via USB * Start the VM * Add the Floorboard to the VM USB * Do everything else within the VM, download and install Monkey, open Monkey, login via Monkey, yada yada and it should all work fine
  4. Line6 Helix Stomp 3.0.0 HX Edit 3.00 via USB Mac OSX 10.15.7 Slow Filter Down does not change filter direction or impart any audible change. Filter always travels upward. Hit me up if you're hiring senior software QA. SlowFltDownBug.hlx
  5. Which of the Helix models support two unique instrument inputs through two 100% separate mono signal paths and separate outputs? My goal is to have one single multieffect unit that I can connect two instruments to simultaneously, but maintaining their own distinct signal chain so I can run them to two channels FOH. Then I can flip-flop between instruments without having to also flip-flop between patches. Bass into input 1, maintain its own mono signal path probably with comp/drive/amp sim/chorus/delay, output to its own mono output. Hardware synth into input 2, maintain its own mono signal path with whatever fx is needed, output to its own mono output.
  6. I have Monkey 1.65 for Mac. It has no Gear Box option. However, I could manually select Gearbox form the product list in downloads and obtain it there, seems to be working fine. Way too hard. :)
  7. Just illustrating the difficulty I'm having finding this information as a new user. * Visit the X3 Live page: http://line6.com/legacy/podx3live and observe it's fairly non-functional. But in the header there's "Custom Tone". * Visit the Line6 Custom Tone page, there's patches galor, but there's nothing clearly indicating what app to use: http://line6.com/customtone/browse/podx3/ * Click Help to hopefully get some help, there's no direct downloads for whatever app should be used, and it only textually references Line6 Edit. Or try this. * Visit the Downloads page and select POD X3 Live and Mac OS X: http://line6.com/software/index.html * You have to scroll 2/3 of the way down the [very long] page to even find GearBox and it doesn't clearly mention what it's function is. I'm not at home with my X3 Live to check, but I did install Monkey and I don't recall it including an option to install GearBox, Line6 Edit, or any other obvious software to help me out with this. Thanks for your help, I'll try GearBox later this week and report back.
  8. Picked up a used Line X3 Live, struggled to figure out which app allows sharing / downloads of patches (not linked to on the X3 Live Mac downloads page, nor does Monkey list it), eventually found mention of Custom Tone and Line6 Edit, and managed to download and install Line6 Edit. However, it will not run on my system and keeps throwing the following error dialog. "To open "Line 6 Edit," you need a Java SE 6 runtime. Would you like to install one now? Not Now / Install" However, I currently have Java 7 installed from Oracle which supersedes 6 which was managed by Apple and is no longer offered on the latest Mac OS X versions. System: * Macbook Pro 15" Early 2008 2.5 GHz Intel Core 2 Duo 4GB * Mac OS X 10.8.5 * Java 7 Update 45 (latest version)
