Matrix_87 Posted February 24, 2015 Share Posted February 24, 2015 Hi guys, I need some help.I've just bought the Amplifi Fx100 and I'm trying to record some guitar track on FL studio connecting the pedal board to my computer by USB, but......it doesn't work! The computer doesn't see the guitar at all. I anticipate I'm not an expert user of FL Studio (I've just started using it), so it maybe a problem of audio configurations or something like this.I have Asio4All and I have updated my Amplifi firmware.Thank you in advance! Quote Link to comment Share on other sites More sharing options...
Triryche Posted February 24, 2015 Share Posted February 24, 2015 Have you flashed the FX100 to the current firmware? Have you installed the USB Audio driver? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 24, 2015 Share Posted February 24, 2015 Use the Line 6 ASIO usb driver. Do not use ASIO4ALL. Quote Link to comment Share on other sites More sharing options...
Matrix_87 Posted February 25, 2015 Author Share Posted February 25, 2015 Ops, problem solved.I just had to download Line 6 ASIO usb driver :PReally thank you!But now I have another question.I have played a bit with the recording and when I play normally, I can hear my sound as I set it (I use headphones), but then as soon as I press Rec the sound seems weird, like double, and more metallic. Do you have any explanation for this_? Quote Link to comment Share on other sites More sharing options...
Triryche Posted February 25, 2015 Share Posted February 25, 2015 I don't use FL Studio, But it sounds like you may have "Monitoring" (may be called something else) turned on. Or a plug-in effect. Or both. Quote Link to comment Share on other sites More sharing options...
adagosto Posted February 25, 2015 Share Posted February 25, 2015 That's exactly what came to mind as I was reading your post. Triryche may have got it. The monitoring could be on. If you monitor through the same speaker of headphones that you are playing through and there is even a tine bit of latency, you will get that weird sound. If this is NOT the cause of the weird sounds you're hearing, try reducing the output volume of your speakers when you're recording. See if that changes anything. Just curious, should have asked this before...when you hear the weird sound, does that weird sound actually get recorded? How do the recordings sound? Quote Link to comment Share on other sites More sharing options...
Matrix_87 Posted February 26, 2015 Author Share Posted February 26, 2015 The recording sounds exactly how I hear it while recording, which is different compared to the sound out of FL studio.Actually it's not only while recording, the sounds changes as soon as I assign the guitar to one of the channels of the mixer in FL studio. Quote Link to comment Share on other sites More sharing options...
Triryche Posted February 26, 2015 Share Posted February 26, 2015 The recording sounds exactly how I hear it while recording, which is different compared to the sound out of FL studio. Not sure I follow that statement. What do you mean by "different compared to the sound out of FL studio"? Quote Link to comment Share on other sites More sharing options...
Matrix_87 Posted February 27, 2015 Author Share Posted February 27, 2015 I mean...if I play without any program, just connecting my headphones to the Amplifi, all good.If I open FL Studio (just open), still good.In the exact moment when I put my guitar on one of the mixer channels in FL studio, than it becomes a bit more metallic and weird.The same obviously during the recording, and it is also recorded like this. Quote Link to comment Share on other sites More sharing options...
Triryche Posted February 27, 2015 Share Posted February 27, 2015 I am not familiar with the FL Studio interface. Are you selecting somewhere in the software the FX100 ASIO as your device? Sorry for sounding dense, but can you explain how you put your guitar to one of the mixer channels? Quote Link to comment Share on other sites More sharing options...
Matrix_87 Posted February 27, 2015 Author Share Posted February 27, 2015 First I select the Line 6 Asio for Amplifi in the audio interface.Then I openthe mixer panel and clicking on each channel you can assign what you want to put on that channel. In my case I can choose between Amplifi stereo R/L, Amplifi Left, or Amplifi Right. I'm not sure what these options mean, because whatever I select nothing changes in term of sound. But anyway, when I select one of these, then FL studio feels my guitar when I play and I can also start recording.But at the same time, when I select one of these option (it doesn't matter which), the sound get weird. Quote Link to comment Share on other sites More sharing options...
Triryche Posted February 27, 2015 Share Posted February 27, 2015 I'm wondering if you have an overall effect engaged somewhere in FL, like a plug-in. The FX100 has two channels, L and R, so those 3 options are allowing you to select L, R, or L/R (both). Selecting L/R will give you the stereo signal of the FX100. Did you try searching or posting in the FL Studio forums too? Quote Link to comment Share on other sites More sharing options...
