oehman Posted April 2, 2015 Share Posted April 2, 2015 Anyone else had server issues? When I start up Line 6 monkey (v 1.7), it hangs for a long time (4-5 minutes)on the start up screen "contacting Line 6 server". When it finally goes to the next screen, it says "could not connect to Line 6 server to determine if updates are available. Make sure you are connected to the Internet and click check for updates" I've been getting this message since I purchased the new model packs and wanted to install them. i even removed the Monkey program from my computer (Windows 7) and re-downloaded & reinstalled it. Last night, I just figured the server was overloaded by everyone downloading and installing the model packs. But I couldn't get it to log on this morning or tonight. My internet connection is fine. The other issue I may have is that the email address that was listed in my account is no longer active. So when I purchased the model packs, it sent an email to an account that I no longer use or have access to. Is there an activation code in the email that gets generated when you buy the model packs? Or are the model packs installed when you log in to Line 6 Monkey? Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted April 2, 2015 Share Posted April 2, 2015 When you are able to sign in to your account next time you can update your new e mail address. Go to the "my settings" tab under your user profile and you can change and confirm the e mail change. Look on the left side of the screen near the top. The servers are probably very busy now with the new releases. I am not sure how they confirm payment for the downloads. Good luck sorting things out! Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted April 2, 2015 Share Posted April 2, 2015 When I had this problem it was my antivirus software that was keeping Monkey from talking to Line6. 1 Quote Link to comment Share on other sites More sharing options...
MonkeyXT Posted April 2, 2015 Share Posted April 2, 2015 Same here; I tried to update, and my Norton security software flagged it as having SONAR heuristic v(xx) and that it would best be removed. Caution to all on this, just in case there's a security issue. 1 Quote Link to comment Share on other sites More sharing options...
mscozza Posted April 2, 2015 Share Posted April 2, 2015 Similar problem here (only the error message is slightly different)I was able to connect only the first time I installed Monkey, some months ago, since then I cannot connect either from Monkey and/or from License Manager.I've tried to disable firewall and antivirus, but nothing changes.When I sign up on the website it works fine.Obviously due to this problem I'm not able to upgrade to the last firmware and this is annoying... Quote Link to comment Share on other sites More sharing options...
oehman Posted April 2, 2015 Author Share Posted April 2, 2015 Looks like it might be antivirus software related. I logged on using a different laptop and everything went well. Downloaded License Manager, logged in, registered devices, and updated via Monkey. Then reran License Manager, and it installed the model packs. Quote Link to comment Share on other sites More sharing options...
mscozza Posted April 2, 2015 Share Posted April 2, 2015 I have disabled my AV: nothing.I have opened my firewall (on the router): nothingI have disabled my personal firewall (on the PC): nothing.Must I buy another PC only to authorize or update my HW products?Obviously it sounds crazy, isn't it?I'm a computer engineer so I'm not totally ignorant about connection issues, and these pieces of software are the only ones giving me problems.I'm happy with my POD-HD-PRO-X stuff, but if I have to be stuck due to annoying sw protection related problem....well I'll never buy Line6 products. Quote Link to comment Share on other sites More sharing options...
ddewees Posted April 3, 2015 Share Posted April 3, 2015 I'm blocked on trying to run Monkey in OSx so I'm unable to get Firmware upgrade. I've tried backing down a few versions of Monkey but no luck. I was hoping to get this installed and buy the Classic model pack but will be waiting until this issue is resolved. Quote Link to comment Share on other sites More sharing options...
stromgitarrist Posted May 17, 2015 Share Posted May 17, 2015 Same problem ! Is there already a solution ?? Quote Link to comment Share on other sites More sharing options...
ddewees Posted May 17, 2015 Share Posted May 17, 2015 I was able to get things to work about a week later. Not sure if thi issue was on my end or l6. Quote Link to comment Share on other sites More sharing options...
