Punkyboy Posted May 22, 2015 Share Posted May 22, 2015 hello is it possible to calibrate an second expression pedal I mean an external one?? with the FBV Shortboard MK II TX Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted May 22, 2015 Share Posted May 22, 2015 Are you using hte Line 6 EXP expression pedal? If so, yes. I have heard that other mfr expression pedals don't play well with the FBV. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 22, 2015 Author Share Posted May 22, 2015 Not a Line 6 It's a M-Audio but it's not good working with the FBv? can not set the minimum value to 0% it stay on 16% but no problem finaly I send it back for refund Bu I have another one the Zoom this working very good but it's a bit too high and the course I mean between the up & down is too small sorry speaking french But Tx Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 22, 2015 Share Posted May 22, 2015 There is no calibration process for external pedals. The external pedal jack is simply looking at the resistance from the potentiometer in the pedal. The EX1 uses a 10kOhm linear pot (well actually it uses two 20kOhm pots wired in parallel, but the overall resistance is still 10kOhm). Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 22, 2015 Author Share Posted May 22, 2015 which expression pedal are compatible with the FBV Shortboard excepted de Line 6 one? Is there a list of compatible pedals? because the line 6 one is very expensive for a plastic one i'm interesting for the Electro Harmonix Expression Pedal but Hell yeah do it works??? Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 22, 2015 Share Posted May 22, 2015 The only pedals that are officially supported are the EX1 and the Mission Engineering EP1-L6. There are other pedals that will work - you just have make sure they have the correct pot inside. There's a partial list of compatible pedals in this old thread: https://www.google.com/?gws_rd=ssl#q=mission+engineering+ep1-l6 Another one that's not on that list that should work well is the Dunlop DVP3. The nice thing about that one is that it can be used as a volume pedal, and it has internal controls that allow to reverse the heel/toe positions and adjust the min and max values. http://www.jimdunlop.com/product/dvp3-volume-x Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 22, 2015 Author Share Posted May 22, 2015 Ok Thank you very much Phil Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 29, 2015 Author Share Posted May 29, 2015 Finaly I buy the EX1 and it works perfect Quote Link to comment Share on other sites More sharing options...
