rmoskal74 Posted July 9, 2015 Share Posted July 9, 2015 I see that the Helix can support multiple amps which is a huge selling point for me. However, in my experience, there is often a lot of trouble shooting to eliminate noise, hum, ground loops, etc. when putting together a rig with two amps via 4CM (or in this case 7CM). Is this an issue with the Helix? Quote Link to comment Share on other sites More sharing options...
stevekc Posted July 9, 2015 Share Posted July 9, 2015 or in this case 7CM In September, post a pic of your 7 cable method multi-amp setup ! Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 9, 2015 Share Posted July 9, 2015 I see that the Helix can support multiple amps which is a huge selling point for me. However, in my experience, there is often a lot of trouble shooting to eliminate noise, hum, ground loops, etc. when putting together a rig with two amps via 4CM (or in this case 7CM). Is this an issue with the Helix? Well, ground loops are always a possibility, and it's not really the fault of any single device you're connecting. It's really a complex issue. I have tried Helix connected via the 4CM with my Egnater Renegade, and I had no issue with noise. I haven't tried the 7CM. I actually don't know if I have enough cables laying around to do it! Quote Link to comment Share on other sites More sharing options...
rmoskal74 Posted July 9, 2015 Author Share Posted July 9, 2015 Well, ground loops are always a possibility, and it's not really the fault of any single device you're connecting. It's really a complex issue. I have tried Helix connected via the 4CM with my Egnater Renegade, and I had no issue with noise. I haven't tried the 7CM. I actually don't know if I have enough cables laying around to do it! I rarely run into issues with a single amp (a mini rec or mini mark) but when I try to run both through my rig I have to add hum eliminators somewhere in the chain. Not a big deal if I have to continue to do that was just being optimistic that it would be a simpler plug-n-play type thing. Guess we will wait and see... Quote Link to comment Share on other sites More sharing options...
bartnettle1 Posted July 10, 2015 Share Posted July 10, 2015 I think anyone using multiple amps will be a touring professional and likely know or have the Techie available to ensure there are no phase issues. This ability to run multiple amps is going to lure even bigger selling professional to the Helix. It is a huge plus for getting tones that near rival expensive touring rigs. Lets hope the FX count increases Quote Link to comment Share on other sites More sharing options...
Tboneous Posted July 10, 2015 Share Posted July 10, 2015 As soon as Line 6 expands Helixs ability to fully control it's fantastic DT series amps via L6 link, then hooking up 4 amps is a snap with no noise at all! Quote Link to comment Share on other sites More sharing options...
