Helix Looper
oehman
Silverhead is right, but just to put a finer point on it. You'll only get that 120 seconds when running the looper in mono and recording your loop after you've pressed the half speed switch. In stereo, the max loop time is 60 seconds. Operationally, the looper on the Helix is identical to the looper on the 500X. The main differences are that you have a choice between inserting a mono or stereo looper, and you can put the looper block wherever you want in the chain. Also, the looper isn't automatically in every patch. If you want it in a patch, you have to insert it.
  • Upvote 2
  • 1 month later...
  • 2 weeks later...
