Switch between signal paths?
progmr
1. assign both AMPs A+B on a single FS
2. set AMP A=ON , AMP B=OFF
3. set BYP VOL=0 an both AMPs
4. set mixer PAN : path A =100%L, path B=100%R
5. make sure 2 achieve complete separation btween paths A / B.
6. mixer must b the last thing in the chain (exceptions exist, will further explain if requested)
by pressing the assigned FS u r actually toggling btween PATH A / B.
alternatively, u can fade in-out each path by reversely assigning AMPs A+B CH VOL @EXP 1/2, so that:
-when EXP 1/2 is @MIN position,  AMP A CH VOL=0,      AMP B CH VOL=MAX (only AMP B is heard)
-when EXP 1/2 is @MAX position, AMP A CH VOL=MAX, AMP B CH VOL=0      (only AMP A is heard)
-when EPX 1/2 is @INTERMEDIATE position, u get a proportionally mixed signal from BOTH AMPs.
  • Upvote 2
Or...
Just put path A under Patch i.e. 1A and the other under 1B,
Don't make it complicated when it can be a piece of cake!
Or do I mis something here!
You can do that for two separate patches, yes. But the OP is talking about a dual-amp patch, for which there are many uses. The expression pedal method allows for a seamless fade-in/fade-out transition from one tone to another without the (sometimes) audible gap that accompanies switching between two patches. It's a game-changer for live players who switch between clean and dirty tones a lot...it allows for a much cleaner execution of those changes.
