manatopain Posted September 22, 2015 Share Posted September 22, 2015 Hi everybody! i just spent the last hour creating a really beautiful patch and i have it saved and all. but sadly, when i go from the patch to another patch, and then return to the patch, the path B is muted! inside the mixer, it stays on the same, +0.0dB which it is saved as, but the path is - as said - muted. I only need to click on the mixing slider, and the path is returned to +0dB - although there is no visual change in the slider. can anybody help me with this? It's really annoying, and pretty much makes the patch useless, if i can only listen to the path B while im editing the patch. Notes: I'm editing the patch in pod HD500 edit. Patch is attached. Quote Link to comment Share on other sites More sharing options...
jandrio Posted September 23, 2015 Share Posted September 23, 2015 pls attach patch Quote Link to comment Share on other sites More sharing options...
manatopain Posted September 23, 2015 Author Share Posted September 23, 2015 The patch is uploaded in a zip file in the post below. Quote Link to comment Share on other sites More sharing options...
jandrio Posted September 23, 2015 Share Posted September 23, 2015 still not attached. hint: try attaching zip file. Quote Link to comment Share on other sites More sharing options...
manatopain Posted September 23, 2015 Author Share Posted September 23, 2015 there we go! :) Shimmering.h5e.zip Quote Link to comment Share on other sites More sharing options...
jandrio Posted September 24, 2015 Share Posted September 24, 2015 opening patch in "HD500 Edit" (no pod attached), i read foll mixer settings:path A= -7.0 db centerpath A= -0.5 db centerso it was saved with abv settings (and not with 0 db).anyway, i do not c any problems in ur patch.attaching patch with mixer settings = 0db. Shimmering-corrected.zip Quote Link to comment Share on other sites More sharing options...
perapera Posted September 26, 2015 Share Posted September 26, 2015 hi this is a known bug it has to do with the edit software communication with the pod the workaround is: when this happens, after you send the correct patch to the pod you need to also save the patch on the pod itself (by pushing the save button 2 times) 2 Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted October 27, 2015 Share Posted October 27, 2015 hi this is a known bug it has to do with the edit software communication with the pod the workaround is: when this happens, after you send the correct patch to the pod you need to also save the patch on the pod itself (by pushing the save button 2 times) this didn't work for me. I tried exactly what you suggested: 1st I dragged and dropped the patch into the Pod HD edit, and the Path A was muted, even though the indicator was at -4dB. 2nd I moved a bit the level of the Path A and placed it again at -4dB, so it can work well again. 3rd I clicked twice the "Save" button on my Pod HD 4th I changed the patch with another from the saved ones and then I changed back to the patch that has the bug and it still had that bug Am I doing anything wrong here? :/ Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted October 27, 2015 Share Posted October 27, 2015 this didn't work for me. I tried exactly what you suggested: 1st I dragged and dropped the patch into the Pod HD edit, and the Path A was muted, even though the indicator was at -4dB. 2nd I moved a bit the level of the Path A and placed it again at -4dB, so it can work well again. 3rd I clicked twice the "Save" button on my Pod HD 4th I changed the patch with another from the saved ones and then I changed back to the patch that has the bug and it still had that bug Am I doing anything wrong here? :/ Ok I just made it work. This time I just corrected the mixer by using the Pod's buttons entirely and then double-clicked "Save" and now it works! Thank you so much, perapera! Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted October 27, 2015 Share Posted October 27, 2015 Ok I just made it work. This time I just corrected the mixer by using the Pod's buttons entirely and then double-clicked "Save" and now it works! Thank you so much, perapera! Nevermind, it didn't work. When I keep adding patches in the setlist, the bug returns and I need to fix it again. Thanks, Line 6 -.- Quote Link to comment Share on other sites More sharing options...
aerosol_d7 Posted October 27, 2015 Share Posted October 27, 2015 Known bug, no idea when line 6 will solve. http://line6.com/support/topic/14187-patch-creation-bug/?do=findComment&comment=112238 Quote Link to comment Share on other sites More sharing options...
Indianrock2020 Posted October 29, 2015 Share Posted October 29, 2015 I've noticed something similar when a patch has a foot switch assigned to one of the two amps in the signal path. One amp winds up turned off. So I have to double-check all foot switch assignments. I don't assign FS to amps so assuming this happens when footswitch assignments are edited for other effects. Quote Link to comment Share on other sites More sharing options...
