pwh589 Posted November 25, 2015 Share Posted November 25, 2015 when im on a effect i try to use the tap to change the tempo of a specific pedal.maybe i dont know how to do this correctly... Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 25, 2015 Share Posted November 25, 2015 In the FX parameters there is a Tempo setting that allows you to specify whether the tempo of the FX is fixed (a number of ms) or will respond to the Tap Tempo switch (a note value). Make sure that is set to a note value. Quote Link to comment Share on other sites More sharing options...
rogb777 Posted August 15, 2020 Share Posted August 15, 2020 Tap but will not set tempo and in the settings it is set to Global. Any ideas? Quote Link to comment Share on other sites More sharing options...
stormstudios Posted August 16, 2020 Share Posted August 16, 2020 Which effect are you using that is mapped to the tempo? And, subsequently, what's the setting dialed in at within the effect block? Quote Link to comment Share on other sites More sharing options...
