markionico Posted December 14, 2015 Share Posted December 14, 2015 Hi guys! I'd like to know if someone had some experience about this configuration with Helix: -----------------<----- DAW (via USB) for reamping + Backing track | ^ | | | | | Path 1 A in from Guitar ------> FX 1, 2, … ------------> (stereo) 1/4†and XLR output | | B in from Guitar ------- > FX 1, 2, ... ------------> (stereo) 1/4†and XLR output | | Path 2 A in from AUX ------ > FX 1,2, ... ------------> (stereo) 1/4†and XLR output | | B in from USB x/y (DAW) ------------------------> (stereo) 1/4†and XLR output | | |____________> | I read the the manual and It seems possible but I'd like to receive some comment or suggestions. Thank you Mark Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted December 14, 2015 Share Posted December 14, 2015 I think you have to be more specific ? What is your goal? Is FX 1, 2,... The same as FX 1, 2,... in the next path, or ? Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted December 15, 2015 Share Posted December 15, 2015 I'm not sure exactly what you need to happen with each path. But yes you can have 4 separate paths with separate inputs and outputs on each. And yes path 2A can use the aux input while 2B can use USB channels as its input (and output) for re-amping. If your plan is to record two guitar tones and a backing track simultaneously I would recommend switching the backing track/aux path to 1B, and moving the second guitar path to 2A to get better use of your DSP on both paths. Quote Link to comment Share on other sites More sharing options...
markionico Posted December 15, 2015 Author Share Posted December 15, 2015 Thank you You are right, my topic is not so clear I'll try to explain better I'd like to play guitar with backing track from a DAW via USB interface I need to use two paths for double Guitar sound (path 1A e 1B). The backing track from USB goes directly to the main out (2a) and the backing track with clik for the drummer goes to send output (2B). I'll try to write a scheme.... Quote Link to comment Share on other sites More sharing options...
markionico Posted December 15, 2015 Author Share Posted December 15, 2015 I hope that the image attached makes what I need clear! Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted December 16, 2015 Share Posted December 16, 2015 Well... Do you want effects on the backingtrack ? Otherwise there is no reason for you to use a path for these... If you setup Helix as your playback-engine it will come trough Helix... And you should be able to choose which output to send to... Quote Link to comment Share on other sites More sharing options...
markionico Posted December 16, 2015 Author Share Posted December 16, 2015 Well... Do you want effects on the backingtrack ? Otherwise there is no reason for you to use a path for these... If you setup Helix as your playback-engine it will come trough Helix... And you should be able to choose which output to send to... Quote Link to comment Share on other sites More sharing options...
markionico Posted December 16, 2015 Author Share Posted December 16, 2015 No, i dont need effect on backing track ... But please tell me Moore about "Setup helix as playback engine" Thaks Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 16, 2015 Share Posted December 16, 2015 I think he means to configure your DAW to use Helix as the audio input/output device. That should happen automatically when Helix is connectd via USB to your computer, but you may have to go to the Audio Setup section of your DAW and specify that Helix and its ASIO driver be used. When things are set up like this the DAW will playback existing (previously recorded) tracks through Helix, so you will be able to hear the backup track(s) while playing your guitar. This uses USB Inputs 1/2 to Helix from the DAW. However, the title of your thread mentions reamping. Yet (unless I misunderstand) nothing you've described includes reamping, which means routing a previously recorded track inthe DAW to a Helix input for processing. Is that what you are trying to do? If so, you can send any track(s) from your DAW into USB 3/4 or 5/6 as Helix inputs to any path for reamping. Quote Link to comment Share on other sites More sharing options...
markionico Posted December 17, 2015 Author Share Posted December 17, 2015 Thank you, Guru I have now clear how I can connect DAW and Helix like a playback system. At the same time I am still interested to investigate different configuration that are possible with Helix for different live situations. One is simply to playback a track but sometimes I need to reamp a pre-recorded guitar loop and to play a backing track without effects. Therefore, if I understand well, it's possible at the same time (same live performance): - to use path 1A and B for FX with guitar at the input - to use path 2A and B for alternatively: > reamping a track prerecorded from the 3/4 or 5/6 channel USB input and addressed at the 1/2 output > play a backing track (with click for drummer) prerecorded from the 3/4 or 5/6 channel USB input and addressed at the Send output - to play a backing track from the DAW without FX directly to 1/2 output Correct? I hope I have been clear Thank you very much Mark Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 17, 2015 Share Posted December 17, 2015 Yes - you've got it. Have fun! Quote Link to comment Share on other sites More sharing options...
