Sign in to follow this
talwilkins
Problem setting Output to Digital
I have a strange problem.
I made a preset as seen on the picture:
The signal paths are as follows:
Path 1A is a seperate path to be usaed for a microphone so I can put some effects on my voice.
Path 1B is for guitar and continues to path 2A.
Pathe 2A splits after the amp to path 2B with a Y-split.
Path 2B Contains some post amp effects. I do this to have a signal without the delays going to the output as wel as a singnal with delays. This makes my guitar playing more articulate, not completely being delayed.
Both 2A and 2B ar set to Digital output because I send to my DT25 through Line6 Link.
The problem (bug?):
If I change the output to something else I can't return to Digital. Somehow the digital output is not available, eventhough it's selected allready.
Why is this? Am I doing something wrong? Is it a bug?
I have the same problem.
Workaround: go to preset with a digital output and copy the output and paste it to the target preset.
I think it' s a bug.
If Helix sees an L6 LINK device (like DT25), L6 LINK takes over and that Digital Out parameter does nothing.
Ah, that makes kind of sense. Thanks!
It would be a little less confusing if Line6 LINK wasn't mentioned behind the Digital output then)
Still, thinking about it some more I'm still confused.
You say Line 6 Link takes over when Helix sees a DT25.
What does Line 6 take over? It doesn't take over my signal going to XLR, so how exactly does it work?
Create an account
Register a new account
Sign in
Sign In Now
