mikeosbornma Posted March 2, 2016 Share Posted March 2, 2016 Maybe there is an easy way to do this, but I can't figure out. Can I assign a stomp box to more than one foot switch? What I would like to do it have separate controls for each box then have one switch that could turn on/off multiple boxes. I know I can assign parameters to a single switch but can I assign on/off functions? Thanks, -Mike Quote Link to comment Share on other sites More sharing options...
hideout Posted March 2, 2016 Share Posted March 2, 2016 Yes you can. If you know how to assign it to a footswitch you can repeat the process for every effect you want to turn on and off. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 2, 2016 Share Posted March 2, 2016 Part of what the OP is asking is about assigning multiple FS to control a single FX. That's not possible. What can be done, as you describe, is to assign multiple FX to a single FS. @mikeosbornma: you will need to use multiple instances of the same FX and assign each to their own FS. This may or may not be able to achieve exactly what you want. If not, rethink what you are trying to achieve. Chances are it's ultimately inconsistent. Can you describe your goal in more detail? Quote Link to comment Share on other sites More sharing options...
duncann Posted March 2, 2016 Share Posted March 2, 2016 The topic title suggests wanting to assign the same effect block to multiple switches. As a sort of workaround, you could assign an effect block to one switch and the mix parameter (if it has one) of the same effect block to another switch. I think in effect you're wanting something like scenes. Which Helix cannot really do, yet. A combination of what hideout, silverhead, and the text above here is about the best you do. 2 Quote Link to comment Share on other sites More sharing options...
mikeosbornma Posted March 2, 2016 Author Share Posted March 2, 2016 Yes, scenes is exactly what want! I'll see what I can do with adjusting the mix, but its less than optimal. Does anyone know if scenes are on Line6's radar for Helix (I'll search the forums). Thanks for the help! -Mike 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted March 2, 2016 Share Posted March 2, 2016 Scenes are definitely on Line 6's radar: http://line6.ideascale.com/a/dtd/Helix-Scene-Mode/727231-23508 Quote Link to comment Share on other sites More sharing options...
ajfkeith Posted March 2, 2016 Share Posted March 2, 2016 There is an Ideascale posting for this. Here's the link to vote: http://line6.ideascale.com/a/dtd/Multiple-switches-for-1-block/801153-23508 Quote Link to comment Share on other sites More sharing options...
