BigRalphN Posted March 17, 2016 Share Posted March 17, 2016 Ok. As much as I have used this I should have this down. For some reason I can't seem to get this. All I am trying to do is make a simple A/B switch. I want it to stomp the switch to choose either a the Red Squeeze or the Minotaur (I used another forum numbers advice and have it set up as a sweet clean boost). It is driving me crazy. I am doing something basic wrong. Inge them both on the switch but either both go off and on or one is staying on. I hate when miss something easy. Any help is appreciated. Thanks guys. Maybe I just need to step away for 30 minutes. Quote Link to comment Share on other sites More sharing options...
glideman Posted March 17, 2016 Share Posted March 17, 2016 You have to navigate to one or the other pedal and use the Bypass button to toggle it to the opposite on/off state of the other one. Then save it with the button in the state you want when initially called up. Quote Link to comment Share on other sites More sharing options...
duncann Posted March 17, 2016 Share Posted March 17, 2016 What glideman says, and also, when assigning the second effect, make sure to have it merge, rather than replace. Quote Link to comment Share on other sites More sharing options...
BigRalphN Posted March 17, 2016 Author Share Posted March 17, 2016 Ok. Thanks a lot guys. I will try it here in a bit. I think maybe I wasn't toggling it properly. *Edit* Thanks again guys.. I got it instantly this time. Super easy. 1 Quote Link to comment Share on other sites More sharing options...
glideman Posted March 18, 2016 Share Posted March 18, 2016 Glad you could follow my mad ramblings off the top of my head. LoL! Quote Link to comment Share on other sites More sharing options...
JLondon Posted March 18, 2016 Share Posted March 18, 2016 I feel your pain dude! This very thing has literally driven me crazy. I've asked for help on this board as well but while I've been appreciative of everyone's answers, nothing really worked for me. No matter what I tried, the result was exactly the opposite. And things can get really ugly, really fast, when you start trying even more complicated combinations That said, I know what Glideman suggested is the correct very abbreviated answer. All I can say is that, for some reason, with time I'm having less of a problem. I don't know exactly what I'm doing different. So I'm afraid I'm not going to be much help. What I do have for you is "hope". (grin) On second thought, try this. Note to yourself which effect (A) you want to be "on" when the switch is "off". Assign this to the switch "first". Then bypass the effect so that the light will go out. Now assign (merge) the effect (B) that you want to become active when hitting the switch. The switch should now be on with effect B "on" and effect A "off" (I think). Now, for God's sake - SAVE! If this doesn't work then try exactly the opposite of what I just said. If 'that' doesn't work, well ... remember the "hope" thing. Quote Link to comment Share on other sites More sharing options...
jaminjimlp Posted March 18, 2016 Share Posted March 18, 2016 Really you don't need to use an a-b switch here you can just have them in the same path. Just one block "on" and one block "bypassed", both assigned to the same toggle. and save it of course. Quote Link to comment Share on other sites More sharing options...
