hideout Posted March 26, 2016 Share Posted March 26, 2016 Hey, Boys and Girls. This is only for those who are handy with a soldering iron. So, I decided to take advantage of the Helix's IEC power connection and power the Helix as well as my RC-20XL looper with one IEC cable. I bought the following items to make it happen; 1) a 9V switch mode power supply 2) Barrel Connectors - 5.5 O.D./2.1 I.D. 3) an IEC "Y" Adapter •Important• With this power supply you'll have to reverse the polarity so that its output is Tip Negative. You can do the same thing for your pedalboard if its power supply uses an IEC connector. Here's the end result. 1 Quote Link to comment Share on other sites More sharing options...
kramer_nut Posted March 26, 2016 Share Posted March 26, 2016 Nice job! Quote Link to comment Share on other sites More sharing options...
hideout Posted March 26, 2016 Author Share Posted March 26, 2016 Nice job! Thanks, Bro! Quote Link to comment Share on other sites More sharing options...
spikey Posted March 26, 2016 Share Posted March 26, 2016 Looks sharp! Quote Link to comment Share on other sites More sharing options...
hideout Posted March 26, 2016 Author Share Posted March 26, 2016 Looks sharp! And tidy! Thanks, Spikey! Quote Link to comment Share on other sites More sharing options...
fab7br Posted March 26, 2016 Share Posted March 26, 2016 Great Idea. I wonder if there's a "9V switch mode power supply" that already have the negative center so we don't have to solder anything Quote Link to comment Share on other sites More sharing options...
spikey Posted March 27, 2016 Share Posted March 27, 2016 There is a 9.6 volt negative center brick used on Boss and Ibanez stomps, part# US9.6DC-200BI Quote Link to comment Share on other sites More sharing options...
hideout Posted March 27, 2016 Author Share Posted March 27, 2016 There is a 9.6 volt negative center brick used on Boss and Ibanez stomps, part# US9.6DC-200BI Ah but does it have an IEC connector? Quote Link to comment Share on other sites More sharing options...
spikey Posted March 27, 2016 Share Posted March 27, 2016 No just the brick a female plug negative center. Quote Link to comment Share on other sites More sharing options...
soundog Posted March 27, 2016 Share Posted March 27, 2016 Interesting you use an external looper pedal when the Helix already contains a looper. But its too darned limiting so I just use it for setup testing. I use an external Boomerang III looper with mine because it allows 2 synched loops. I do wish a Helix update would permit more loop capabilities; especially a second loop option. Sixty seconds would be plenty. Quote Link to comment Share on other sites More sharing options...
hideout Posted March 27, 2016 Author Share Posted March 27, 2016 No just the brick a female plug negative center. Well then it won't be much different from just using any old adapter. The idea is to have fewer cables coming from the power strip. Great Idea. I wonder if there's a "9V switch mode power supply" that already have the negative center so we don't have to solder anything Yeah but then you'll have all this extra cable that you'll have to coil up coming from the 9v adapter. Even if the polarity was correct, I would have cut it off to keep the cable lengths at an absolute minimum and keep things tidy... which is why I did it in the first place. A little O.T. but I really think that every guitar player. bassist, keyboardist, would do themselves a lot of good if they learned some super basic electronics and learned how to use a soldering iron. You should at least learn to fix or even make your own cables. Quote Link to comment Share on other sites More sharing options...
hideout Posted March 27, 2016 Author Share Posted March 27, 2016 Interesting you use an external looper pedal when the Helix already contains a looper. But its too darned limiting so I just use it for setup testing. I use an external Boomerang III looper with mine because it allows 2 synched loops. I do wish a Helix update would permit more loop capabilities; especially a second loop option. Sixty seconds would be plenty. 60 seconds is not nearly long enough for me. I do a verse, chorus, verse, chorus and sometimes a bridge while I'm singing and then start the loop to solo over. Quote Link to comment Share on other sites More sharing options...
soundog Posted March 27, 2016 Share Posted March 27, 2016 ...so Helix more-looper-stuff features could accommodate enough loop time for your hungry needs, but more Mb for loops might limit Mb for memory-intensive Blocks (e.g. IR etc). There's a lot of onboard memory in the box. I'm just sayin' it would sure be nice if a future upgrade would allow more looper features for us loopers. I've already sold off a bunch of my stompboxes that the Helix replaces, but I can't let go of my looper pedal yet. Nice power Y, by the way.... 1 Quote Link to comment Share on other sites More sharing options...
efunkelist Posted March 29, 2016 Share Posted March 29, 2016 Too cool! Brilliant idea! I might have to try this too. Thank you VERY MUCH for sharing and good job! Quote Link to comment Share on other sites More sharing options...
audionutmike Posted March 29, 2016 Share Posted March 29, 2016 Nice! I guess that's next to do on my DIY list Great job! Quote Link to comment Share on other sites More sharing options...
