AeroUSA Posted April 26, 2016 Share Posted April 26, 2016 I recently got a Henriksen Bud amp and I was trying to use the Helix as an effects only unit. The problem is that connecting with XLR has a lot of hiss. Connecting with a guitar cable works fine. Does anyone have the solution for this? Thanks Aaron Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 26, 2016 Share Posted April 26, 2016 Turn off the phantom power on your Bud amp input. Quote Link to comment Share on other sites More sharing options...
AeroUSA Posted April 26, 2016 Author Share Posted April 26, 2016 It cannot be turned off unfortunately. It's always on. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 26, 2016 Share Posted April 26, 2016 Then the hiss will be there on the XLRs until and unless Line 6 resolves the issue. Meantime use the Helix 1/4" outputs. Quote Link to comment Share on other sites More sharing options...
AeroUSA Posted April 26, 2016 Author Share Posted April 26, 2016 Does changing from Line level to XLR fix it? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 26, 2016 Share Posted April 26, 2016 Not to my knowledge but worth a try. Quote Link to comment Share on other sites More sharing options...
klangmaler Posted April 26, 2016 Share Posted April 26, 2016 Knowledge Base: http://line6.com/support/page/kb/_/effects-controllers/helix/helix-xlr-outputs-and-48v-phantom-power-r771 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 26, 2016 Share Posted April 26, 2016 If it sounds fine with a guitar cable, just use that. For short distances, you won't hear much if any difference between unbalanced and balanced. Quote Link to comment Share on other sites More sharing options...
AeroUSA Posted April 26, 2016 Author Share Posted April 26, 2016 I'll do that. Thanks so much! Quote Link to comment Share on other sites More sharing options...
Lachdanan0121 Posted April 26, 2016 Share Posted April 26, 2016 Not to hijack the thread but does the Hiss happen if the only phantom power that is on... is the one that is powering the mic input on the Helix itself, and recording with a mic? Or is it if there is any other Phantom power device in the chain other than the Helix? Although come to think of it, that won't be much of a problem as when recording with the Mic, we will be using headphones anyways. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 26, 2016 Share Posted April 26, 2016 It affects the Helix XLR Outputs when the connected device is delivering phantom power through its XLR inputs. This issue does not affect the Helix XLR Inputs, whether or not the Helix phantom power is on. Quote Link to comment Share on other sites More sharing options...
