cjowen Posted May 21, 2016 Share Posted May 21, 2016 So I have owned a UX2 with a MXL 990 mic for awhile now but recently I've noticed an issue, namely that after about 5 to 10 minutes of playing a video game, with PodFarm open, the microphone no long picks up my voice. The meters on podfarm move half a bar or so, if I tab out of the game and wait, sometimes the mic will come back, only to cut out again when I tab back in. I've tried multiple usb ports Using both Mic inputs I changed my power plan for both the USB and Hard disk I raised the buffer size I updated drivers But nothing seems to do the trick. It only seems to happen when playing a game, it doesn't effect skype or anything else that would use my microphone. Is there something I missed? I hope someone can be of help Thank you. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted May 26, 2016 Share Posted May 26, 2016 What O/S are you using? There is a setting in Win7 that basically fills up a memory location from any audio being used and when it fills up, it shuts down. rebooting clears it out, then it starts again. Been quite a few years since I changed my settings, I don't remember the details now. Quote Link to comment Share on other sites More sharing options...
cjowen Posted May 26, 2016 Author Share Posted May 26, 2016 What O/S are you using? There is a setting in Win7 that basically fills up a memory location from any audio being used and when it fills up, it shuts down. rebooting clears it out, then it starts again. Been quite a few years since I changed my settings, I don't remember the details now. Oh wow! I am indeed using windows 7 so that very well seems like a a major suspect. Do you remember anything that would give me a base to research where this setting is? Anything would help. Thank you for this reply, I was starting to lose hope. Ha. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 26, 2016 Share Posted May 26, 2016 Studio condenser mic,... you are using phantom power? Use phantom power on condenser mics only,... nothing else. Quote Link to comment Share on other sites More sharing options...
cjowen Posted May 26, 2016 Author Share Posted May 26, 2016 Studio condenser mic,... you are using phantom power? Use phantom power on condenser mics only,... nothing else. Yes, I do have the phantom power turned on for my mic, which is a condenser, correct? I should have specified. Thank you for the advice regardless. Like I said, the mic works in skype and everything else, the problem only occurs while running games through steam. The sound remains, it's just the microphone that gets cut and sometimes if I unplug the mic from the UX2 and reconnect it, the mic picks up for only about a minute or two before cutting again. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 26, 2016 Share Posted May 26, 2016 "I should have specified"--- only with a UX2 or UX8. I always ask since I see too many come across my bench, because someone kicked in the phantom power while using a dynamic mic, killing the UX2 or UX8 in the process. You're okay then. Quote Link to comment Share on other sites More sharing options...
cjowen Posted May 26, 2016 Author Share Posted May 26, 2016 Well if it's not that, do you have any ideas of what could be causing my original issue? What could be causing the drops? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 27, 2016 Share Posted May 27, 2016 Video games,... running 64 bit, instead of 32 bit? I ask because it's something I've come across recently, dealing with several audio apps from different companies, running on the same computer. Where one app is running 64, the other 32, and memory getting filled while the CPU boggs down. Not sure if that's the case here, but having gone thru this myself recently, I know it's a possibility. Quote Link to comment Share on other sites More sharing options...
