frankiman Posted June 7, 2016 Share Posted June 7, 2016 With the pod we had the option to either select a patch with the bank and then use all 8 switches with different effects or use the bank to store up to 4 patches then once a patch is selected you could use only the top 4 switches to turn on/off effects. I find i cant do the latter on the Helix or am i wrong? Can someone explain if this would be possible. Thanks again. Quote Link to comment Share on other sites More sharing options...
glideman Posted June 7, 2016 Share Posted June 7, 2016 I believe you can things up this way. There is a 10 Stomp mode with no bank up/down. There is a mode where you can have bank up/down with 8 preset switches. There is a mode where you can have bank up/down with 4 preset switches on the bottom and and 4 stomps on the top. You can also have it flip flopped for presets on top and stomps on bottom. I also believe that you can select to have the bank buttons instead be preset up/down buttons. I would assume this would allow preset up/down plus 8 stomps. It's all in the global settings menus I believe. 1 Quote Link to comment Share on other sites More sharing options...
frankiman Posted June 7, 2016 Author Share Posted June 7, 2016 thanks glideman i'm starting to figure it out. had to go to the pedal itself and i was only trying to do it with the editor on the pc Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted June 8, 2016 Share Posted June 8, 2016 With the pod we had the option to either select a patch with the bank and then use all 8 switches with different effects or use the bank to store up to 4 patches then once a patch is selected you could use only the top 4 switches to turn on/off effects. Press MENU and then Knob 6 (Global Settings). Use the joystick to select the Footswitches submenu and turn Knob 2 (Preset Mode Switches) to "Lower Row." Four Stomps appear on the top row and four presets appear on the bottom row (like HD500X's default state) To view 8 stomps, just press MODE to select Stomp footswitch mode. Global Settings are not accessible from the editor software. Quote Link to comment Share on other sites More sharing options...
roscoe5 Posted June 8, 2016 Share Posted June 8, 2016 Wow, learned something new on that one. Could be very useful. Thanks for the post and responds guys! Quote Link to comment Share on other sites More sharing options...
