It's Freeset Friday!!!
sminchk67
How do you get 2 ir cabs on this one, if im setting mine exactly like yours, im not able to put in the second 3party ir cab?
After the amp, press the joystick and select the 1st IR as normal.  Then use the action button and move it down to path b.  Press action to release.  Use the joystick to move back up to the block that was just vacated.  Press the joystick and add the 2nd IR in the old one's place.
That creates the dual path split after the amp feeding the two IRs.
