LesSand Posted June 14, 2016 Share Posted June 14, 2016 I need to simulate a clean boost (like the MXR micro amp) in front of an amp. I'm thinking of using a Param EQ to simulate the MXR's high-end boost at unit gain, and then the Level parameter as gain. In addition to using my ears, am also trying to think this through. :-) - Does that sound like a reasonable alternative to you guys or am I tripping? - Are these blocks designed to be loaded like this and react like in real life, or am I risking digital clipping between blocks? I started fussing with it right in front of the Amp block's input, I haven't yet tried in front of other pedal blocks. - Is the +16dB (I think?) gain offered by the EQ's Level parameter on par with the type of gain a pedal of that type gives in the real world? Thoughts? Peace, -Ale Quote Link to comment Share on other sites More sharing options...
FacemanJoe Posted June 14, 2016 Share Posted June 14, 2016 This should help. https://www.youtube.com/watch?v=9y3tg33qMNI Quote Link to comment Share on other sites More sharing options...
esarlag Posted June 15, 2016 Share Posted June 15, 2016 many thanks :) Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted June 15, 2016 Share Posted June 15, 2016 Best clean boost I've found is the Klon with the Gain all the way down. 1 Quote Link to comment Share on other sites More sharing options...
Dshow Posted June 16, 2016 Share Posted June 16, 2016 Best clean boost I've found is the Klon with the Gain all the way down. I use that too most of the time. Especially works great with amp settings on the edge of breaking up. Here's a quick video: https://youtu.be/RJchKith71c Quote Link to comment Share on other sites More sharing options...
Tcamponovo Posted June 17, 2016 Share Posted June 17, 2016 The EQ will work. I also like to use the Klon model as well as the Screamer with the gain down and level up. Sometimes I use a compressor for this as well but I think it takes a little more work to make it not sound like a compressor. Quote Link to comment Share on other sites More sharing options...
watch4king Posted June 20, 2016 Share Posted June 20, 2016 +16db sounds a little high but yes, the Helix is supposed to behave like in real life with pedals in front of the amp. Try the Klon like others have suggested.... or even both. Personally I use the Timmy or the Klon and happy thus far. Good luck! Quote Link to comment Share on other sites More sharing options...
