SpiderM69 Posted March 31, 2017 Share Posted March 31, 2017 New to Helix, and the forum. I'm trying to import demo IR's from Ownhammer and RedWire. I just upgraded to firmware 2.20. I get a "Malformed URI" when I try to import in the editor. This happens with both companies' demos, and whether I select a group of files, or a single file. Same when I try to drag the files from file explorer. I'm running Windows 7. Any ideas on what might be causing this? I haven't imported IR's before, but it looks pretty straightforward to me, and I did read the instructions. Any help is greatly appreciated. Thanks, Steve Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 31, 2017 Share Posted March 31, 2017 Are you sure you're grabbing the 48 KHz wav versions of the IRs? I believe that each of these companies give you the IRs in multiple formats and sample rates. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted March 31, 2017 Share Posted March 31, 2017 I thought I read that Helix (Editor or the Helix itself) would take care of the sampling resolution conversion, if necessary, upon import? Or, might that be solely for a one IR at-a-time import basis; not for a batch operation? Quote Link to comment Share on other sites More sharing options...
SpiderM69 Posted April 1, 2017 Author Share Posted April 1, 2017 I have been importing the 48K, although resolution is 24 bit. I believe Helix converts to 48K/16 bit when samples are higher. I get the same error message when importing single or multiple IR's. Quote Link to comment Share on other sites More sharing options...
