chuskey Posted September 16, 2013 Share Posted September 16, 2013 On the parallel pitch tab does it only allow for +12 or 0? I noticed in the manual it says that it defaults to +12 kind of implying, in my mind, that you could use other values. But that doesn't seem to be the case when I try it with Workbench. What I was trying to do was figure out a way to emulate a Micro Pog with 1 octave up, 1 octave down, and regular pitch. I had in mind that I could use alt tuning to drop an octave, parallel pitch to go up 2 octaves (+24), and blend in the magnetic pickups for standard tuning. I figured it was a long shot, but worth a try. I haven't actually messed with this via the guitar, I just had the idea while I was at work and loaded up the software to see if it was theoretically possible. Any ideas on how this could be done? Quote Link to comment Share on other sites More sharing options...
dkemusic Posted September 16, 2013 Share Posted September 16, 2013 No the pitch shifting is up to +/- one octave. Dan Quote Link to comment Share on other sites More sharing options...
soundog Posted April 9, 2016 Share Posted April 9, 2016 How do you get -12 (octave down) parallel? My Workbench HD with Variax Standard only allows me to do Parallel Pitch at +12 (an "octave up"). No other options are available to me ... just +12 or nothing. My Variax 700 Acoustic (using the old non-HD Workbench) allow any setting, including -12 (octave below) parallel. That's what I want to achieve (on just my low E and A strings). Its sounds nice and beefy, like a bass playing in unison. But I can't get this on my Variax Standard (or JT). Yes, I can achieve this tone somewhat using the Variax magnetic pickup blend. But that limits me to standard tunings, so I can't use alternate tunings for this. Or I could set my tuning up -12 and use +12 parallel (to get standard tune), but that sounds crappy and nowhere near as natural as the -12 setting available on the VA700 with original Workbench. So .... is there anyway to simply dial in Parallel Pitch at -12 (an octave below) my base string tuning? Quote Link to comment Share on other sites More sharing options...
